Project LS Non-VTEC begins.
Old Sep 28, 2006 | 01:07 PM
b19coupe's Avatar
Default Project LS Non-VTEC begins.
After installing a stock B20B in a friend's car and tuning it with some Crower 403's and Hondata, I got the bug to build an all motor non-VTEC engine. I needed a stock LS to begin with, so yesterday I picked up a fairly clean 1994 Integra LS.
Today I baselined the vehicle and it made a respectable 120/133. Then we plugged in a Hondata S300 and made a few passes to clean up the A/F and timing maps. The tired bone stock motor made 127/135.
The project motor is off getting sleeved to 85mm, the pistons are on order, the head and the intake manifold are being ported by Import Builders, a stock B20 crank is getting reworked by Castillo, a JDM 4-1 ITR header is sitting in the garage, next to some Crower 405A Non-VTEC cams, so when it all comes together, the car goes back on the dyno for some more tuning. The compression will be in the neighborhood of 11.5:1. More on the project as it developes...
Old Sep 28, 2006 | 01:12 PM
ALLMOTA92EG's Avatar
Default Re: Project LS Non-VTEC begins. (b19coupe)
thats gonna be one sick motor
Old Sep 28, 2006 | 02:15 PM
DAmn's Avatar
Default Re: Project LS Non-VTEC begins. (Jdmcivichb!)
****** a right
Old Sep 28, 2006 | 02:55 PM
dc-lefty's Avatar
Default Re: Project LS Non-VTEC begins. (DAmn)
another nonvtec build !
Old Sep 28, 2006 | 03:12 PM
JCushing's Avatar
Default Re: Project LS Non-VTEC begins. (dc-lefty)
ya saying im following this build is an understatement.
howd you get that hump at 3200 on a stock motor, looks like its got a CAI on it...
dont you love that 8 ft/lb dip at 4k you get with a stock IM and cams
Old Sep 28, 2006 | 03:13 PM
D-Rob's Avatar
Default Re: Project LS Non-VTEC begins. (JCushing)
In for the results.
Old Sep 28, 2006 | 05:17 PM
b20sedan's Avatar
B20 Bhai M.B.B.S
Default Re: Project LS Non-VTEC begins. (D-Rob)
Eerie, it's like looking in a mirror isn't it?
I've got a green 4-door Integra with B20Z and GSR transmission. Although, I've got 403's in my closet just waiting to be installed...so mine is a milder version of your build ..can't wait to see your results
Modified by b20sedan at 7:03 PM 9/28/2006
Old Sep 28, 2006 | 05:38 PM
fmrprojects's Avatar
Default Re: Project LS Non-VTEC begins. (b20sedan)
sounds like a good build
Old Sep 28, 2006 | 06:28 PM
AViciousTHRUST's Avatar
Old Sep 29, 2006 | 05:43 AM
TehMan's Avatar
Default Re: Project LS Non-VTEC begins. (AViciousTHRUST)
sounds like a good built...i had an all motor ls in my civic with 404s crower dual valve springs and crower retainers sitting on jdm itr pistons. but i went the itb route instead of a intake manifold. it was a really nice set up. good luck
Old Sep 29, 2006 | 08:13 AM
flesh199's Avatar
Default Re: Project LS Non-VTEC begins. (TehMan)
great project
Old Sep 29, 2006 | 09:05 AM
AMLS4dr200whp's Avatar
Default Re: Project LS Non-VTEC begins. (flesh199)
good luck with the project hope u can show those people non vtec can make power too
Old Sep 29, 2006 | 09:47 AM
hybrid_vtec's Avatar
Im in for the progress and the results of this build. Too bad Im not still out in SD. I woudnt mind checking a build like that out once it was done.
Good luck!
Old Sep 29, 2006 | 12:12 PM
Mikey361's Avatar
Default Re: Project LS Non-VTEC begins. (hybrid_vtec)
bump dis sheet homie,
Old Sep 29, 2006 | 02:00 PM
HYBRID FREAK's Avatar
Gonna be interesting.
Old Sep 29, 2006 | 03:33 PM
dohcMONSTER's Avatar
Default Re: (HYBRID FREAK)
TTT for Todd, looks good can't wait to see the numbers.
i'll be seeing you soon with my new motor as well
Modified by dohcMONSTER at 5:00 PM 9/29/2006
Old Sep 29, 2006 | 03:55 PM
ne3ek's Avatar
Default Re: (dohcMONSTER)
yes def following this..
Old Sep 29, 2006 | 04:55 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
Default Re: (ne3ek)
i just sold a customer a straight LS i rebuilt years ago and never ran. only performance improvement was radiused/recontoured piston tops. it went into a 2000 Si with matching tranny to replace a blown b16 while i repaired some broken guides... and i couldnt believe how great the thing went from idle to about 6,000 rpm with stock intake and ex system, completely untuned.
when the b16 head went back on with a .015" mill, valvejob and some chamber/throat cleanup it obviously picked the power up to 8k or so, but really took a dive on the off-idle torque from the ports getting so much larger.
anyways, nothing wrong with nonvtec.
Old Sep 29, 2006 | 08:04 PM
b19coupe's Avatar
Removed the stock exhaust manifold, cat, and b-pipe today. Installed a JDM ITR 4-1, straight pipe, and ITR B-pipe today. Thanks to Brian at After Hours for a little exhaust fab work Car feels better, but only the dyno will tell for sure. I am going to try and get back on the dyno tomorrow and see what gains/losses the exhaust change made. Hopefully will be able to start assembling the 2 liter motor next week.
Old Sep 29, 2006 | 08:09 PM
ne3ek's Avatar
Default Re: (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Removed the stock exhaust manifold, cat, and b-pipe today. Installed a JDM ITR 4-1, straight pipe, and ITR B-pipe today. Thanks to Brian at After Hours for a little exhaust fab work Car feels better, but only the dyno will tell for sure. I am going to try and get back on the dyno tomorrow and see what gains/losses the exhaust change made. Hopefully will be able to start assembling the 2 liter motor next week.</TD></TR></TABLE>
ya the itr 4-1 is pretty good.. i suffer a lot of low end from it though :/ i think i kinda prefer tri-y's but what do i know
Old Sep 30, 2006 | 07:59 PM
b19coupe's Avatar
Default Re: (ne3ek)
Quick update-put the car on the dyno-made a couple of passes to clean up the A/F. Picked up a fair amount of power by replacing the stock exhaust with the JDM ITR 4-1 header, no cat and an ITR B-pipe:
Old Oct 1, 2006 | 05:25 AM
ne3ek's Avatar
wow thats a significant increase all around..!
Old Oct 1, 2006 | 11:36 AM
b19coupe's Avatar
Default Re: (ne3ek)
Had some free time and did some more tuning. Installed an AEM CAI from my ITR in an attempt to get rid of the nasty LS dip at 4,000 RPM-it worked! This tired little LS motor is starting to break the tires loose in first gear !!!
Old Oct 1, 2006 | 11:44 AM
BearsEK-KMSU's Avatar
Im curious how you are going to make the new motor work with 405's with 11.5/ 1 compression. You could make it 13:1 to one and still run pump with those cams
Old Oct 1, 2006 | 11:48 AM
damn todd, now your getting me even more excited haha. looks great! those are some awesome gains
