Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Pilot towing questions??
Old Sep 28, 2006 | 11:57 AM
razzergreen's Avatar
Default Pilot towing questions??
I have graduated from my 04 accord to an 04 Pilot so I only need one vehicle. Has anyone ever wired one of these with an electric trailer brake controller? I have the plug-in that mated to the vehicle harness, but it only goes to a four flat. Also, are there any recommendations for how to tow with a Pilot? OD/ no OD? I am used to shifting out of the top gear for towing, but the honda manual says nothing about it?? In lower that D4, it seems way to high of RPM....thx
Old Sep 28, 2006 | 12:47 PM
DaiJekBok's Avatar
Default Re: Pilot towing questions?? (razzergreen)
I'm not sure about wiring in the brake controller -- you can check http://www.hondapilot.org for more information on that -- but tow in D5 per the manual. Also, make sure you have the required tranny and power steering fluid coolers as well.
Old Oct 2, 2006 | 08:03 AM
Thx, i 'll check there too...
Old Oct 7, 2006 | 04:39 PM
skunked's Avatar
Default Re: (razzergreen)
Have you bought the trailer brake controller or does the trailer have a built in actuator to control the brakes?
If your trailer is not equipped with a brake control device you need to get one. I use this one and it came with a harness that plugged right into the brake harness under the dash of my 2500HD Silverado.
http://www.tekonsha.com/prodig.html
Old Oct 7, 2006 | 07:47 PM
Ross 2.0's Avatar
In a Junkyard near you.
i know the ridgeline is equipped with a trailer brake kit (with the factory towing kit) but i'm not sure about the pilot. i'll check the electrical manual later to see if it's supported.
Old Oct 7, 2006 | 10:31 PM
skunked's Avatar
Default Re: (Ross 4107)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ross 4107 &raquo;</TD></TR><TR><TD CLASS="quote">i know the ridgeline is equipped with a trailer brake kit (with the factory towing kit) but i'm not sure about the pilot. i'll check the electrical manual later to see if it's supported.</TD></TR></TABLE>
what exactly is a"kit" though?
Old Oct 8, 2006 | 05:23 AM
Ross 2.0's Avatar
the towing kit?
Hitch, wiring harness, ball hitch, drop hitch pin (or locking pin).
Trailer brake kit = control unit, wiring harness, some sort of a brake force sensor wether it be gravity or brake pedal sensor
Old Oct 8, 2006 | 10:02 AM
skunked's Avatar
Trailer brake kit = control unit, wiring harness, some sort of a brake force sensor wether it be gravity or brake pedal sensor</TD></TR></TABLE>
I wonder if my Pilot has this? Not that I would ever use it anyway
Old Oct 9, 2006 | 05:21 AM
DaiJekBok's Avatar
The Ridgeline is pre-wired for a trailer brake controller (you get a pigtail with the towing package) -- you have to buy the controller seperately.
The Pilot does not have this wiring.
Old Oct 9, 2006 | 08:16 AM
skunked's Avatar
Default Re: (DaiJekBok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaiJekBok &raquo;</TD></TR><TR><TD CLASS="quote">
The Pilot does not have this wiring.</TD></TR></TABLE>
that makes more sense
Old Oct 12, 2006 | 02:11 PM
APEX CRX's Avatar
Default Re: (skunked)
Since we're on the subject of towing with a Pilot. My 04 Pilot factory hitch has a sticker with tow ratings 4500 boat trailer and 3900 other trailer/auto
what the hell is the difference? I want to see if it would be say to tow my CRX race car on an open trailer. weight of trailer about 1500lbs CRX about 2200 lbs
anyone clear this up?
Old Oct 12, 2006 | 04:18 PM
DaiJekBok's Avatar
Default Re: (APEX CRX)
Honda rates it that way because a boat is more aerodynamic and would be easier to tow than a lighter (but much less aerodynamic) box trailer. Kinda hokey, I know.
I think you'd be able to tow your setup without a bit of trouble.
Old Oct 12, 2006 | 04:26 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">Since we're on the subject of towing with a Pilot. My 04 Pilot factory hitch has a sticker with tow ratings 4500 boat trailer and 3900 other trailer/auto
anyone clear this up?</TD></TR></TABLE>
If I can tow my prelude which is twice the weight of your crx on an 18ft open trailor you will be just fine .
Old Oct 13, 2006 | 10:38 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaiJekBok &raquo;</TD></TR><TR><TD CLASS="quote">Honda rates it that way because a boat is more aerodynamic and would be easier to tow than a lighter (but much less aerodynamic) box trailer. Kinda hokey, I know.
I think you'd be able to tow your setup without a bit of trouble.</TD></TR></TABLE>
AH, That makes a little more sense. cool I figure when I have soem more cash and space I'd like to pick up a nice open aluminum trailer. The CRX is more of a dedicated track car now a days anyhoo. thanks
Old Oct 18, 2006 | 04:06 PM
actually is says 4500, and 3500 for non boat?? Thats what mine says.
Glockinator
Nov 7, 2018 06:56 AM
jnb0111
Oct 21, 2015 12:11 PM
CanadianEh48
Feb 16, 2009 08:25 AM
1991hondahatchsi
May 26, 2006 05:09 PM
