what should I buy
Old May 1, 2002 | 01:55 PM
95hybridcivic's Avatar
Default what should I buy
I am going to have about $700 dollars back from taxes and I am wanting to spend it on engine mods. I am aware that this amount is not going to get me a whole lot but every little bit helps. What would you guys buy with the money? Cams, intake mainfold.etc... thanks
95 civic with jdm B18c
DC 4-1 header
tanabe racing medalion
CAI
Old May 2, 2002 | 03:38 PM
feriocious's Avatar
Default Re: what should I buy (krrrrrrzyrebel)
cams
Old May 2, 2002 | 04:09 PM
94civicx's Avatar
New User
Default Re: what should I buy (aftermidnight)
cams
Old May 2, 2002 | 04:13 PM
Cone's Avatar
Default Re: what should I buy (94civicx)
Skunk2 Stage 2 cams, drop in they don't give you much, but tuned in a good N/A motor (chipped ECU, S2 IM, 2.5" exhaust, etc) it will get good numbers. You can start off with the cams for a decent boost, then tune them up later when you get more money. If you want to do NA, you could also start up with CTR pistons and ITR rods. The IM wouldn't help much, you'll lose your low end cuz you don't have big cams to use the extra air the IM adds. Just to let you know, a good mild NA set up would be, IMO, Skunk2 Stage 2 cams, CTR pistons, ITR rods, valvetrain, Skunk2 IM, full 2.5" exhaust (JDM 4-1 too), and some good fuel tuning. You should see at least 200whp with that set up (I know I am probably missing some things) but yeah...HTH...
-Andrew
[Modified by Stealth 95 GS-R, 8:17 PM 5/2/2002]
Old May 2, 2002 | 04:14 PM
SIK IN DA HED's Avatar
New User
Default Re: what should I buy (Stealth 95 GS-R)
what mods do you currently have?
egsr92
Sep 8, 2007 08:16 PM
Sparkles
15
Nov 21, 2006 09:48 AM
gutted
Nov 17, 2003 05:17 PM
juggernaut
Oct 5, 2003 06:05 AM
blakacintegera
Jul 21, 2003 12:52 AM
