AFR question on a H23
Old Sep 28, 2006 | 07:52 AM
Pullig's Avatar
Default AFR question on a H23
Ok i have a bone stock h23 no-vtec with just the basic i/h/e . Ive also got a Innovate LC-1 hooked up. Ive got a feeling somthing isnt right with my fueling system. Its overly rich. Idle its around 12.5-13s. Cruising it is the same. WOT is WAY FAT in the mid-low 10s. I know they run rich but that bad aint no way. Im running stock computer p14 and no check codes. I was thinking maybe the fuel pressue regulator could be the culprit. Any ideas guys?
Old Sep 28, 2006 | 08:07 AM
Hawkze_2.3's Avatar
Default Re: AFR question on a H23 (Pullig)
Could be FPR, what's your fuel pressure? Do you have a gauge or anything?
Old Sep 28, 2006 | 08:34 AM
98vtec's Avatar
moderator emeritus
Default Re: AFR question on a H23 (Hawkze_2.3)
yea thats a TAD rich.
what is it while holding a load at part throttle cruising? If you are running closed loop, it should be 14.7:1, even if your fuel pressure is a little high.
give us some more details....
Old Sep 28, 2006 | 08:42 AM
Pullig's Avatar
Default Re: AFR question on a H23 (98vtec)
I have no idea what the Fuel pressure is i have no gauge.. Well when im in say 16-18in hg. its around 12.5-13.5 Then around 10in hg its in the 12s. Its been blowing lots of black smoke in wot and ive been fouling out plugs lately. how can i go about checking the FPR?
Old Sep 28, 2006 | 08:49 AM
98vtec's Avatar
moderator emeritus
well, there are kits out there where you can check your fuel pressure. I'm pretty sure autozone has them
http://www.amazon.com/Actron-C...V2BI2
how old is your o2 sensor? It may help to take it off and clean the tip.
Old Sep 28, 2006 | 09:01 AM
Pullig's Avatar
Well i dont understand how the narrowband o2 sensor has anything to do with WOT. From my understanding the ECU totally ignores it in WOT and goes into a set map to control fuel. Thanks for the help ill just try to get a pressure tester and see where its at.
Old Sep 28, 2006 | 09:03 AM
98vtec's Avatar
moderator emeritus
it has nothing to do with WOT, but you are running rich at part throttle as well as WOT. My first instinct would be to check the fuel pressure.....let us know how that goes.
Old Sep 28, 2006 | 11:28 AM
PirateMcFred's Avatar
Is it just me or are you running some big Delta regrinds with that P14?
Pirate
Old Sep 28, 2006 | 01:19 PM
Pullig's Avatar
Default Re: AFR question on a H23 (PirateMcFred)
naw im not running those anymore. I couldnt ever get them to act right. The stalling out was killing me plus when i did a compression check with those cams i had 20 psi less in one cylinder then the rest. So i put the Stockers back in and the compression went back even all the way across. Im guessing one of the lobes wasnt in spec like it should have been. to delta id never buy there cams again .
Modified by Pullig at 4:30 PM 9/28/2006
AyOhOndA
May 23, 2010 06:05 PM
Dabrybry
Dec 4, 2008 08:50 AM
Dabrybry
Nov 24, 2008 07:54 PM
LoseRPunKx182
Sep 15, 2005 09:40 AM
hybridpatient95
Dec 28, 2004 09:27 AM
