obd0 sensors on obd1 harness??
going to dive into my ls swap this weekend and I'm wondering if I have to swap over all the obd1 sensors from my d15 onto the b18a or if the obd0 sensors can be reused??
I already have an obd1 distributor for the ls and was told to re-use the civic harness and just lengthen a few wires so I'm assuming there's no difference in any of the sensor plugs??
also, I have the obd0 map sensor since I'm reusing the obd0 intake manifold, or can I swap the d15's throttle body onto the ls?? or should I just toss the obd0 map sensor on the firewall, run the vac hose to it, and wire it in?? does it share the same plug??
EF9-CIVIC
12
Oct 2, 2006 08:21 PM
