HELP......................Brand new............
Old Sep 27, 2006 | 08:37 PM
96azure's Avatar
Default HELP......................Brand new............
I love my Prelude and I haven't had to do anything in 215,000 miles.
Now when I start it, as soon as it comes down from the fast idle is stalls at every light until it gets hot. Then it idles rough. Any ideas.
It has new wires, plugs, cap, idle control valve, PCV valve...........AURGGGGG!!!
Chris
Old Sep 27, 2006 | 09:12 PM
mgags7's Avatar
check the fast idle control valve....
Old Oct 4, 2006 | 02:32 PM
96azure's Avatar
Default Re: (bb4ever)
It just dawned on me that they replaced the cap because it had a large crack in the side of it. Would this indicate something is wrong with the distributor?
Chris
Old Oct 4, 2006 | 06:45 PM
lude_si_95's Avatar
Default Re: (96azure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96azure &raquo;</TD></TR><TR><TD CLASS="quote">It just dawned on me that they replaced the cap because it had a large crack in the side of it. Would this indicate something is wrong with the distributor?
Chris</TD></TR></TABLE>
fix the cap first and find out.
Old Oct 5, 2006 | 07:58 AM
96azure's Avatar
Default Re: (lude_si_95)
I did, and it still does it. Here's what it does again.
Starts fine........slight missing.
Stalls when it comes off the fast idle.
Stalls at lights until its hot.
Slow acceleration and poor idle.
I think it might be the distrubutor going bad.
Old Oct 5, 2006 | 08:39 AM
fast_honda's Avatar
Bad distributors can give bad idling, but before you purchase one of those, have you checked your spark plugs/wires. It sounds like some sort of ignition problem though, so it's either the cap, rotor, distributor, spark plug wires, or spark plugs, and it doesn't sound like it would be an ignition coil. When those go out, your car will stall when it gets hot, yours does the opposite. I hope this helps.
Old Oct 5, 2006 | 10:50 AM
96azure's Avatar
Default Re: (fast_honda)
Yeah, the local Honda/Acura shop put new wires, cap, and plugs, so I think it must be the distributor at this point.
canadianr
Oct 19, 2009 09:10 AM
sloweh3
47
Jan 2, 2009 07:45 AM
stephane613
Jan 19, 2008 06:53 PM
bizmackus
Feb 16, 2007 06:34 PM
Accord88
Feb 23, 2003 05:53 AM
