Is this -3an Will I need an oil restrictor
Old Sep 27, 2006 | 06:26 PM
nuttybumpo's Avatar
Default Is this -3an Will I need an oil restrictor
Old Sep 27, 2006 | 07:01 PM
abnaasefmb's Avatar
Default Re: Is this -3an Will I need an oil restrictor (nuttybumpo)
looks like 1/8npt to 3an, kinda hard to tell. what kind of turbo?
Old Sep 28, 2006 | 03:57 AM
nuttybumpo's Avatar
Default Re: Is this -3an Will I need an oil restrictor (abnaasefmb)
t3/to4e 60 trim .63 ar
Old Sep 28, 2006 | 05:50 AM
nuttybumpo's Avatar
Default Re: Is this -3an Will I need an oil restrictor and oil return
also have a question about oil return line
I have a 5/8 Barb return tapped into myoil pan.
What kind of oil drain flange shall I get
Obviously I have a 5/8th drain line too.
Old Sep 28, 2006 | 12:02 PM
abnaasefmb's Avatar
Default Re: Is this -3an Will I need an oil restrictor and oil return (nuttybumpo)
http://www.atpturbo.com/Mercha...e=OIL
Old Sep 28, 2006 | 12:59 PM
riceball777's Avatar
it does not matter if you run a -3 or -4 line
you are always supose to run a .06 restrictor for t seris non ball bearing turbos and a .03 restrictor for ball bearing turbos
Old Sep 28, 2006 | 01:08 PM
DRAGLS's Avatar
Default Re: Is this -3an Will I need an oil restrictor (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">it does not matter if you run a -3 or -4 line
you are always supose to run a .06 restrictor for t seris non ball bearing turbos </TD></TR></TABLE>
WOW, yea ok. Are you 100% sure about this?
Old Sep 28, 2006 | 01:29 PM
VtecCarHauler's Avatar
Default Re: Is this -3an Will I need an oil restrictor (DRAGLS)
yeah r u sure. I am trying to figure out if I need a res. on my SC61
Old Sep 28, 2006 | 01:41 PM
TURBOFTW's Avatar
Default Re: Is this -3an Will I need an oil restrictor (VtecCarHauler)
DONT run a resistrictor on a standard journal bearing turbo...Run a -3an line and if you have a good oil drain you will not have a problem...
Old Sep 28, 2006 | 02:24 PM
y7turbo's Avatar
Default Re: Is this -3an Will I need an oil restrictor (PeakBOOST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PeakBOOST &raquo;</TD></TR><TR><TD CLASS="quote">DONT run a resistrictor on a standard journal bearing turbo...Run a -3an line and if you have a good oil drain you will not have a problem...</TD></TR></TABLE>
not 100% true.
i say buy one, have it handy. if you dont want to use it and your turbo ends up not smoking then return or sell it. if it ends up smoking then you have it around.
dont be cheap its only a few bucks.
Old Sep 28, 2006 | 02:28 PM
TURBOFTW's Avatar
Default Re: Is this -3an Will I need an oil restrictor (y7turbo)
Whats not true? You don't need a oil resistrictor period...If only you saw how many calls and turbos we recieve for rebuilds due to people running oil restrictors....
Old Sep 28, 2006 | 02:39 PM
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PeakBOOST &raquo;</TD></TR><TR><TD CLASS="quote">Whats not true? You don't need a oil resistrictor period...If only you saw how many calls and turbos we recieve for rebuilds due to people running oil restrictors....</TD></TR></TABLE>
can you give us a number of how many of these turbos you receive. Also what brand and setup they were running -- any other clues as to why they need a rebuild? kinked return lines maybe?
also... any pics of your HD? i've searched and can't find anything
Old Sep 28, 2006 | 02:49 PM
TURBOFTW's Avatar
Default Re: Is this -3an Will I need an oil restrictor (tegasaurus)
Im sorry but i havent kept track of exactly how many...Ill tell you this though majority of the time when a turbo fails it from oil starvation, oil contamination, or hot shut down...
Heres a pic of my hd
Old Sep 28, 2006 | 03:17 PM
Bailhatch's Avatar
I put a restrictor in every turbo I install. Never had one fail but I have replaced lots of turbos that others have installed and had blown seals from too much oil volume/pressure.
When i make mine I use a .063" or .070" for non BB.
Old Sep 28, 2006 | 03:18 PM
TURBOFTW's Avatar
Default Re: Is this -3an Will I need an oil restrictor (Bailhatch)
Well good luck
Old Sep 28, 2006 | 07:06 PM
y7turbo's Avatar
maybe i have bad luck or something but with -3an feed and 3/4" i.d return hose i had some smoking on 1 brand new garrett t25 , one dsm 14b.a restrictor solved the problem. now i use a .055" restrictor on my t3 and i ahve no problems. i even put a gauge on it after the restrictor just to check the pressure.
5-7psi at idle and 28-30 psi from 4krpm to redline. my current t3 has been happy on this for over 20k miles.
like i said, go spend the few bucks and buy one, if you end up needing it you have it. if you end up not needing it then your out 15 bucks. who cares about 15 bucks?
Old Sep 28, 2006 | 07:14 PM
nuttybumpo's Avatar
Mine is a -3an 1/4 npt
will that be OKAY
Old Sep 28, 2006 | 07:53 PM
Attaus's Avatar
I tend to trust Peakboost on this one.. just a hunch seeing as he builds turbo motors for a living.
If you have a good drain too much oil won't be a problem. Just keep an eye on it to be sure.
Old Sep 28, 2006 | 09:36 PM
quicksilver1689's Avatar
i ♥ snails
Hey i dont mean too thread jack but i have a garrett t3 .42/48 turbo do i need a restrictor?
Old Sep 28, 2006 | 10:04 PM
DavidR's Avatar
Default Re: (quicksilver1689)
Avaliable in size 3 and 4.
Old Sep 28, 2006 | 10:14 PM
jDMJeRk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PeakBOOST &raquo;</TD></TR><TR><TD CLASS="quote">Im sorry but i havent kept track of exactly how many...Ill tell you this though majority of the time when a turbo fails it from oil starvation, oil contamination, or hot shut down...
x2....
I see the same **** everyday. We rebuild 3 or 4 turbochargers a week and I cant stress these same points. With a proper drain you shouldnt need a restrictor. But the Garrett GT series turbos do come with a restrictor built in and so does Turbonetics. Most of you dont realize this because the fitting is usually attached to the turbocharger already.
Old Sep 28, 2006 | 10:36 PM
tegasaurus's Avatar
Default Re: Is this -3an Will I need an oil restrictor (jDMJeRk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk &raquo;</TD></TR><TR><TD CLASS="quote">
x2....
I see the same **** everyday. We rebuild 3 or 4 turbochargers a week and I cant stress these same points. With a proper drain you shouldnt need a restrictor. But the Garrett GT series turbos do come with a restrictor built in and so does Turbonetics. Most of you dont realize this because the fitting is usually attached to the turbocharger already.</TD></TR></TABLE>
what about non bb turbonetics? I assume its the same as the non GT garretts in that it doesn't come with a restrictor...
Old Sep 29, 2006 | 05:38 AM
nuttybumpo's Avatar
I have a 5/8 drain line
Old Sep 29, 2006 | 08:35 AM
TURBOFTW's Avatar
x2....
Old Sep 29, 2006 | 11:35 AM
DavidR's Avatar
Default Re: (DavidR)
Avaliable in stright through, as well, -3 and -4.
