Injectors TOO big???
Old Sep 27, 2006 | 05:19 PM
allnaturalb16's Avatar
Default Injectors TOO big???
I recently bought some injectors from a local shop but im not sure what size they are and i was wondering if they are tooooo big will this cause problems or will the ECU only allow a certain amount of gas to be dispersed?? I have mods and will need bigger than stock injectors but if this could cause a prob then i will buy some new RC310s and call it good.
Old Sep 27, 2006 | 10:31 PM
so lazy's Avatar
Default Re: Injectors TOO big??? (allnaturalb16)
whats your setup?
Old Sep 27, 2006 | 10:46 PM
BoostedJeff's Avatar
first of all, why would you buy injectors if you didnt know what they were
Old Sep 27, 2006 | 10:57 PM
greenek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnaturalb16 &raquo;</TD></TR><TR><TD CLASS="quote">I recently bought some injectors from a local shop but im not sure what size they are</TD></TR></TABLE>
you wouldn't buy an engine without knowing the displacement would you?
Old Sep 28, 2006 | 12:14 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Injectors TOO big??? (greenek)
I concur with all responses thus far.
Edit: Although, if your using a standalone engine management setup, you can compensate for most injectors.
Old Sep 28, 2006 | 11:46 AM
well its not your injectors so dont worry, all i want to know is if can cause problems or if only a certain amount of gas will still be sprayed
Old Sep 28, 2006 | 12:23 PM
PhatBoy5015's Avatar
Default Re: (allnaturalb16)
The ECU only controls the amount of time the injector opens. So if you have a bigger injector and a small injector, the bigger one will allow more fuel if they are both open the same amount of time.
Old Sep 28, 2006 | 04:47 PM
greenek's Avatar
if you post pics of them, im pretty sure we will be able to give you a good guess as to who makes them, and then you can contact them from there for specs.
just a suggestion
Old Sep 28, 2006 | 07:27 PM
I dont have any pics but looking at where the gas comes out looks nothing like stock no more lil needle thing in the way. just a gaping hole....
01_ITR
Apr 8, 2009 03:29 AM
allnaturalb16
Sep 28, 2006 07:29 PM
See Are X
Dec 14, 2005 07:29 AM
xtremecoupe
Nov 21, 2005 02:05 PM
b18cx
Feb 28, 2004 09:45 AM
