tranny pop out?s
Old Sep 27, 2006 | 03:11 PM
lsvtec90's Avatar
Default tranny pop out?s
need help guys my tranny is popping out only in 5th gear. what is causing this and what do i need to do to fix it?
Old Sep 27, 2006 | 03:19 PM
Runnerdown's Avatar
Default Re: tranny pop out?s (lsvtec90)
This belongs in the tech forum but....
check the oil level, they usually do that when its getting really low....which also means there is likely a leak so check for that too.
If thats ok, there may be a damaged shift fork. Sometimes people get into the habit of resting their hand on the shifter when cruising in fifth. That leads to wear.
Old Sep 27, 2006 | 03:34 PM
hondachris1994's Avatar
Happened to me to I was low on tranny fluid, cause I do have a leak
Old Sep 28, 2006 | 02:47 PM
lsvtec90's Avatar
ok got it thanks ill check it out
ITRICED
Nov 9, 2009 07:39 PM
Rancidracer86
Dec 18, 2008 06:57 AM
B16Jacques
Sep 17, 2006 09:26 PM
T Rick
Sep 10, 2006 10:03 PM
crxtreme27
Aug 19, 2002 02:11 PM
