LMA bad install ?>?>>>>?
Old Sep 27, 2006 | 12:06 PM
slo_crx's Avatar
Default LMA bad install ?>?>>>>? NO VTEC?
ok well i asked this question in my other thread but it is on a post and several pages back so i think that it will do better if it had its own thread.i searched and searched and came up with nothing,. my problem is my vtec mysteriously doesnt work....
all the wiring is correct .the solenoid even opens when its supose to all that stuff.
the last known time that my vtec has worked was prior to the install of new LMA's and springs /retainers.
so the question is if the LMA's where installed wrong would VTEC not work>>>>?? also what do i looki for to know if they are installed wrong?
Old Sep 27, 2006 | 06:08 PM
PyroProblem's Avatar
Default Re: LMA bad install ?>?>>>>? NO VTEC? (slo_crx)
Theres really only one way to install the lmas unless you put them in upside down.
Did you take the rockers apart? The pins that are inside MUST be in the correct order.Otherwise, no rocker arm locking = no vtec.
Oil pressure ok? No codes?
Old Sep 27, 2006 | 06:19 PM
slo_crx's Avatar
no codes and plenty of oil pressure (about 75-85 psi at WOT)... .. also what do i need to look or to make sure that the pins are in the right order.... pics would help ..lol ..
thanks
alot for everyones help.
Old Sep 27, 2006 | 06:38 PM
Default Re: (slo_crx)
You need the factory service manual. I dont have a scanner so i cant scan mine for you. Im sure there are manuals somewhere online or maybe someone will scan them for you.
Ill try to explain...
There are locking pins that lock the rocker arms together when oil pressure in introduced behind them. Put the pins in so the rocker arms are not locked together. Short pin in the smaller rocker and larger in the mid rocker(I think thats the way)
Hope that helps
Old Sep 29, 2006 | 01:22 PM
DSRxMilogen's Avatar
Default Re: (PyroProblem)
kinda of an obivous thing to do but did you put all the parts back when you put your springs and retainers in? IE the dowel pin and the oil oring in the center of the head under the cam caps....???
Old Sep 29, 2006 | 02:46 PM
slo_crx's Avatar
yeah sure did... i think that maybe the rocker arm assymbly is togehter wrong .. so im gonna go through that some time soon and see if i can find this problem.
(Anthony)
12
Jul 8, 2005 03:26 PM
civic-si-2000
Jun 29, 2003 01:31 AM
