timing balancer quick question help
Old Sep 27, 2006 | 12:03 PM
rollercosta123's Avatar
Default timing balancer quick question help
i am now currently working on my timing belt. am replacing the timing belt , balancer shaft belt, 2 tensioners, water pump, and water pump bolts. I have put on the water pump and the timing belt with the tensioner all in correct timing and all in place but when i come to look at it with the balancer belt is kinda confusing. I have done timing belts before on a civic and corolla so i am kinda familiar with doing it but never did a balancer belt. i have a haynes manual that i purchased at a auto parts store for an extra guide but when i look at it doest really explaine it to me exactly. i see all the timing marks on the front balance shaft but it also says to do it on the rear. i dont see those for the rear balance shaft gear and doesnt show it in the manual. does anyone know this? is there a thread for this. i searched and couldnt find any. if possible and able to please post some pics. thanks
Old Sep 27, 2006 | 12:48 PM
Default Re: timing balancer quick question help (rollercosta123)
anyone???
Old Sep 27, 2006 | 04:58 PM
HONDACURA-DB8's Avatar
Remove the 12mm bolt to access the maintenance hole on the back of the block close to the rear balancer pulley where you would insert a 6x100mm bolt or something equivalent as an alignment tool.
Scribe a line 74mm (2.9in) from the end of the bolt. Insert the bolt into the maintenance hole to the scribe line .
Loosen the adjusting nut to verifythat the timing balancer belt moves freely.
Insert the balancer belt and remove alignment tool.
Courtesy of ALLDATA.
Old Sep 28, 2006 | 02:38 PM
Default Re: timing balancer quick question help (HONDACURA-DB8)
thanks got it.
MikesEJ1
15
Oct 1, 2013 09:22 AM
Stan Koehn
Jul 25, 2009 03:19 PM
Tomakit
Dec 20, 2005 10:39 AM
NotMYHonda
Nov 27, 2005 06:09 PM
SikofFalln
Jun 10, 2002 04:52 PM
