testting waters 90 crx hf w/ jdmb16
just testing waters as far as trades go no trades unless u have a nissan with a swap or a honda with a swap, or a subaru impreza, end of story. as far as price goes im just testing waters, and dont try to low ball me u will just be ignored.
DO NOT POST UNLESS YOU WANT TO BUY, Or bumping, THANKS
B16a from HMO(Roughly 52,XXX)
*Denso Iridium spark plugs
*NGK Spark plug wires
*Hasport Mounts
*S1 tranny stock clutch
*(Just did a transmission flush filled with syncromesh)
*cheapo Intake
*B&M no bend short shifter
*Energy shifter bushings
*New intake manifold gasket
*new oil pan gasket
*OBD1 conversion(Car is OBD1)
*Battery relocated to the back with SCCA approved battery box
*jdm p30 ecu
Exhaust
*DC sports 4-2-1 Header
*Omnipower test pipe
*Greddy SP 2 Exhaust
Suspension
*Tein S-tech springs
*KYB AGX shocks
(Has a very nice ride, and car not slammed)
*Brand new wheel bearings don't even have 1000 miles on them.
*New Tie Rod ends
*New ball joints
*Just had an alignment
*Old Place Racing drag launch crossmember, no peg leg launches
Brakes
*Honda civic EX brakes up front(10.2 inch rotor)
*New pads and new calipers
*DA brake booster and Master cylinder
Wheels
honda hx wheels on brand spanking new falkens
Interior
*Sony headunit
*Full interior
*Optima Red top battery
*Original CRX floormats
the bad
has ac that works, but for some reason its not blowing to the inside of tha car. adn the interior is crappy and needs paint job end point.
here are the pics.
*Hasport Mounts
*cheapo Intake
*new oil pan gasket
*jdm p30 ecu
Exhaust
Suspension
*KYB AGX shocks
*New Tie Rod ends
*New ball joints
Brakes
Wheels
Interior
*Sony headunit
*Full interior
the bad
here are the pics.
kantfadedisazn
Feb 8, 2007 10:23 AM
