need help
coolant full & block burped thru the 12mm bleed screw at the T-stat?
FITV might need to be screwed down a couple turns.
Did some dufus jack the throttle cable too tight? should have a little slack in it.
Lastly you can unplug the IAC and check that the idle drops when it's unplugged; it might have gotten stuck open from years of crud build up.
gabrielsousa
May 2, 2014 07:53 AM
asocallocal
Sep 23, 2010 06:20 PM
Civicman86
Nov 20, 2007 08:51 AM
