ground issue.....
Old Sep 26, 2006 | 08:25 PM
streetracerjoey210's Avatar
Default ground issue.....
ok just a quick question, does a ecu in a honda have to be grounded in order to work proplerly. was thinking of relocate it in to top of dash under air bag slot, so by unbolting and just mounting it in dash . will it cause a problem.
Old Sep 26, 2006 | 08:31 PM
Syndacate's Avatar
Default Re: ground issue..... (streetracerjoey210)
I retract what I just said...
Old Sep 26, 2006 | 08:34 PM
EX-T's Avatar
There are no external grounds on the ECU that I know of. The ground for the ECU is in one of the pigtails. That being said, you should have no problems mounting it under the dash and if you do have problems, just run a ground from the ECU to the bracket in the passenger kick panel to ground it.
Old Sep 26, 2006 | 09:21 PM
Default Re: ground issue..... (EX-T)
thanks ,,,,,,,,,,,,,,will do
dcggames
Sep 28, 2009 12:40 PM
honda_ef9
Nov 19, 2007 05:52 AM
Punker1234
Nov 20, 2005 05:03 PM
Frankei
Nov 4, 2005 06:47 PM
Frcfedintegra
Apr 29, 2003 05:10 PM
