painting value cover???
Old Sep 26, 2006 | 08:06 PM
hmgemperor2003's Avatar
Default painting value cover???
im painting my 94 gsr value cover. what do i use to cover the letters? using tape takes forever with the cutting of each letter. and what kind of sealant do i use so i wont have any oil leak?
Old Sep 26, 2006 | 08:11 PM
Racermech's Avatar
Default Re: painting value cover??? (hmgemperor2003)
Vasoline, then wipe it off when done.
You need to get a new VC gasket to seal the cover to the head. O ya and in the corner you need a little honda bond (or other gasket sealer type stuff)
Old Sep 26, 2006 | 08:13 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: painting value cover??? (Racermech)
Here is all the information you will need to know: https://honda-tech.com/zerothread?id=1362165
Bowers's Avatar
You can use painters tape or you can put a light coating of vaseline on each letter and rub it off the paint later. To reseal, you can get a new valve cover gasket (recommeded) or you can use some honda bond.
Kris's turbo
Acura TL, RL & ZDX
May 6, 2011 06:21 AM
pjr710
Jul 8, 2007 08:00 PM
onah
14
May 14, 2007 11:45 PM
j.dizzle
Apr 14, 2007 06:43 AM
fanta!
Jun 29, 2005 03:20 PM
