Energy Suspension Kit
I am thinking about buying the ES Hyperflex fit. Is it worth the $150 it costs? I know I need to replace some of my bushings anyway (cracked and hard) but should I go this route for a daily driver?
I have ES bushing, so far only on the front. It seems to me that I greased the left side really well. But the right side does have a lot of squeek. Every little bump, squeek squeek squeek. Once in put the back ones in I'll make sure to grease them properly.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastlude69 »</TD></TR><TR><TD CLASS="quote">yea get ready to hear squeak squeak all the time. cuz they tend to squeak a lot. its up to you i have it in my car </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jgonzbb1 »</TD></TR><TR><TD CLASS="quote">I have ES bushing, so far only on the front. It seems to me that I greased the left side really well. But the right side does have a lot of squeek. Every little bump, squeek squeek squeek. Once in put the back ones in I'll make sure to grease them properly.</TD></TR></TABLE>
Which color are you guys using?
I changed the rear suspension bushings about a year ago. I went with OEM.
The main reason was to cut down on vibrations of the ES, and I heard that if you use the inner control arm bushings in the front they won't last very long. The last time I heard that was about 2 years ago, so maybe thats has been corrected.
Guest
Posts: n/a
And you? What color are you useing?
Tiny Tim
35
Sep 22, 2004 05:16 PM
