How-To: 95-96 Center console hazard button rewire
Old Sep 26, 2006 | 05:02 PM
darkspector2.0's Avatar
Default How-To: 95-96 Center console hazard button rewire
A few of you have converted your old center consoles to the newer 95 96 style for the famous cup holder... among better stylings and what not. The 6P connector connects right in but the wires are in the incorrect order. Here is how to change them without hacking up your harness or the switch itself.
First you need to find the 6P connector. Obviously it was connected to your old hazard button.
Next step is to unsecure the "pin lock" by taking a knife or a small screwdriver and prying it back and up.
Then it should look like this
Then take a paperclip and put it into the top(smaller) hole of the pin you need to pull out. Once it reaches the end you should feel a small click.
Pull necessary pins out so you can change the order. This is with the "pin lock" facing you.
The order is: Red/black stripe, White/yellow stripe, Blue/Yellow stripe, Red, Blue, the orange is uneccessary
Hopefully that helps you who have or who plan to switch to the newer style console!
Good luck!
Modified by darkspector2.0 at 4:19 AM 9/27/2006
Old Sep 26, 2006 | 05:15 PM
MadCityLude
Guest
Posts: n/a
Default Re: How-To: 95-96 Center console hazard button rewire (darkspector2.0)
Thanks man. I will do this very soon. I really apreciate it.
Old Sep 27, 2006 | 03:16 AM
skinnyboy's Avatar
great info!
Ive just installed a JDM H22A into mine but rewired the whole car for all the extra JDM goodies, my car is a 95 but i used 93 JDM harnesses, this has helped heaps!
Cheers
Old Sep 28, 2006 | 11:22 AM
dark_rican's Avatar
Nice pics..I did this into my 92 by checking my 94 harness and comparing it to my 92.
Nickvw
Jul 4, 2007 06:15 AM
pugphilly
Honda Civic (2006 - 2015)
May 18, 2006 08:18 AM
Uponforever20x
Jan 3, 2006 09:09 AM
boostaddictgsx
Aug 10, 2005 03:12 AM
