Anybody have Wildwood Dynalite brake calipers or any of the fastbrakes.com kits?
Old May 1, 2002 | 09:38 AM
ILUVTEC's Avatar
Default Anybody have Wildwood Dynalite brake calipers or any of the fastbrakes.com kits?
I am considering the fastbrakes 11" Big brake kit with the Wildwood 4 piston calipers. He has told me that they will fit the factory 15" wheels(and a spacer is provided if not). All that is keeping me from doing it is the fact that the calipers do not have dust seals and in turn require a bit more maintenance. He has said that the piston seals would need to be replaced once a year or so, but not a prob because the seal set is only like $20 and to replace them only takes about 30 minutes each. But he has said that you should check fairly often to make sure that there is no debris between the piston and the caliper wall because of there being no dust sheilds to protect that area. Because these calipers are originally intended for off-road/racing use, in which they would be maintained more regularly anyway, but I would like to use them for the street, so I would like to know if there are any other concerns to have 'cause I dont want them to be more of a problem then benefit. Also, I am located in Orlando Fl where it rains all the time, so I dont know how this could affect them over time, but atleast I do not live up north with all the snow and salt problems. I dont think that it should be too much of a problem, just wanted to know what anyone else thinks. Any comments or suggestions would be greatly appreciated. And anyone have any actual experience with this type of thing? Thanks.
Old May 1, 2002 | 11:35 AM
canuck-mx6's Avatar
Default Re: Anybody have Wildwood Dynalite brake calipers or any of the fastbrakes.com kits? (ILUVTEC)
I am using the dynalites, but I hardly ever drive in the rain, and definitely not in the snow. I have not had any problems with the calipers yet in terms of seals, but I have only had them in since October and probably put less than 1000 km on the car since that time.
I can provide you with a more in depth review after a summers worth of driving with them....so post your question again in September
Old May 1, 2002 | 10:51 PM
vteg's Avatar
New User
Default Re: Anybody have Wildwood Dynalite brake calipers or any of the fastbrakes.com kits? (canuck-mx6)
I await your review also. I have considered the Wilwood kit with the dynalites, but there is a lot of negative press about the lack of seals. I think the dynalites would like living in Cali since there is no weather patterns Just dry freeway.
Old May 2, 2002 | 04:02 AM
sutrusu's Avatar
Default Re: Anybody have Wildwood Dynalite brake calipers or any of the fastbrakes.com kits? (vteg)
omg not WILDwood
WILWOOD
Old May 2, 2002 | 04:34 AM
ILUVTEC's Avatar
Default Re: Anybody have Wildwood Dynalite brake calipers or any of the fastbrakes.com kits? (sutrusu)
Sorry for the misspelling, my bad.
Old May 2, 2002 | 04:35 AM
sutrusu's Avatar
no problem.. just a little annoying
Old May 3, 2002 | 04:22 AM
ILUVTEC's Avatar
charliewolf_0
Oct 21, 2012 06:36 PM
snowblind7x
Dec 21, 2005 09:06 PM
CRX RACER
Feb 20, 2005 09:28 PM
broke
Apr 2, 2002 10:35 AM
