how high do you rev on the freeway
Old Sep 26, 2006 | 03:32 PM
coronadrinker's Avatar
Default how high do you rev on the freeway
just curios how high the gsr, and b16 transmission rev on the freeway and at what speeds, i know its been said before but cant remember and didnt know what to search. thanks
Old Sep 26, 2006 | 03:40 PM
Rikter's Avatar
over 3000K.
I'm not going to go and map out every 10kph what rpm I'm doing. Go drive your car and figure it out? It isin't like there is going to be a wrong answer. It's what your car is doing.
-Rik
Old Sep 26, 2006 | 03:44 PM
doood's Avatar
been there done that
Default Re: how high do you rev on the freeway (coronadrinker)
im at 4k @ 80mph with my gsr tranny. my usual cruising speed.
Old Sep 26, 2006 | 03:48 PM
Default Re: how high do you rev on the freeway (sticky icky)
thanks sticky icky thats on a gsr trans?
Old Sep 26, 2006 | 03:54 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coronadrinker &raquo;</TD></TR><TR><TD CLASS="quote">thanks sticky icky thats on a gsr trans? </TD></TR></TABLE>
yes. any higher and i'd be cruising in vtec. not good on gas.
Old Sep 26, 2006 | 03:58 PM
anybody know how high a b16 revs @ say like 80 or so
Old Sep 26, 2006 | 03:59 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coronadrinker &raquo;</TD></TR><TR><TD CLASS="quote">anybody know how high a b16 revs @ say like 80 or so</TD></TR></TABLE>
~4500
Yambor's Avatar
in the h2b car im around 4300 rpms @ 80. w/b16trans.
Old Sep 26, 2006 | 04:02 PM
Default Re: (Yambor)
all i needed to know guys thanks a lot
Old Sep 26, 2006 | 04:24 PM
dohcMONSTER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sticky icky &raquo;</TD></TR><TR><TD CLASS="quote">
yes. any higher and i'd be cruising in vtec. not good on gas. </TD></TR></TABLE>
you do know that rpm has nothing to do with gas consumption its based off of throttle position
Old Sep 26, 2006 | 04:29 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sticky icky &raquo;</TD></TR><TR><TD CLASS="quote">yes. any higher and i'd be cruising in vtec. not good on gas. </TD></TR></TABLE>
Nope, vtec only activates under full throttle at the rpm usually discussed, 4400 on a gsr for example, but will not activate if you are under partial throttle until 5000. If you're cruising up to 5k rpm, you will not be in vtec. Now, the instant you drop the throttle and are above 4400 rpm it will engage vtec, because you are already above the engagement point. Thats with a gsr, mind you. The values are different for the different vtec cars, a type r will kick in at 5700 rpm under WOT, but will hold out up to 7k depending on throttle position.
Old Sep 27, 2006 | 12:31 PM
iheartintegras's Avatar
Default Re: how high do you rev on the freeway (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">Nope, vtec only activates under full throttle at the rpm usually discussed, 4400 on a gsr for example, but will not activate if you are under partial throttle until 5000. If you're cruising up to 5k rpm, you will not be in vtec. Now, the instant you drop the throttle and are above 4400 rpm it will engage vtec, because you are already above the engagement point. Thats with a gsr, mind you. The values are different for the different vtec cars, a type r will kick in at 5700 rpm under WOT, but will hold out up to 7k depending on throttle position.</TD></TR></TABLE>
Exactly what I was going to say. Though when I do over 80 it seems that my car gets way shittier gas mileage. Like 90mph, maybe I'm imagining it though.
Old Sep 27, 2006 | 12:37 PM
doood's Avatar
hmmm...i've heard of this but was never sure. good to know.
Old Sep 27, 2006 | 03:47 PM
IHTFP's Avatar
Default Re: how high do you rev on the freeway (iheartintegras)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartintegras &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly what I was going to say. Though when I do over 80 it seems that my car gets way shittier gas mileage. Like 90mph, maybe I'm imagining it though. </TD></TR></TABLE>
youre not imagining it...the faster you go, the harder your car works to keep you at that speed....you're working harder and harder against air resistance...
if you could get away w/ 65 youd see way better mileage than at 80
Old Sep 27, 2006 | 03:53 PM
Liquidgsr's Avatar
Default Re: how high do you rev on the freeway (IHTFP)
if im going 80 on gsr with LS tranny im doing about 3500 rpm.
Old Sep 27, 2006 | 05:03 PM
ichbinsobose's Avatar
Default Re: how high do you rev on the freeway (Liquidgsr)
my ls does 4k with a 91ls tranny
i dont know why mine cruises so much higher, but I know for a fact 80= 4k
Old Sep 27, 2006 | 06:29 PM
b20.eg's Avatar
i'm at 3k @60 wih my CTR.
Old Sep 27, 2006 | 08:31 PM
PhoenixDownVII's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHTFP &raquo;</TD></TR><TR><TD CLASS="quote">youre not imagining it...the faster you go, the harder your car works to keep you at that speed....you're working harder and harder against air resistance...
Yea really. I hope you guys realise that "Cruising" at 65, 70, 80 mph is what's worsening your gas mileage, not necessarily the RPM's of that speed.
Slow the heck down, not only do you get better gas mileage, but you get less tickets. I barely cruise 75 (10mph limit above speed limit on highways is my rule lol)....
Old Sep 27, 2006 | 09:28 PM
CompanyFlow's Avatar
Default Re: (PhoenixDownVII)
Cruising at 65 is bad?
Old Sep 27, 2006 | 10:04 PM
stock97's Avatar
Default Re: (CompanyFlow)
of course it is!!!
*runs off to lobby for 55mph freeways like in the 80's*
pfffffttt............expletive that
Old Sep 28, 2006 | 07:02 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow &raquo;</TD></TR><TR><TD CLASS="quote">Cruising at 65 is bad?</TD></TR></TABLE>
Did I say it was bad? No.
But anything above 55mph is actually going to start decreasing your gas mileage, even if you stay at that speed. And, obviously, it gets worse as you get faster, fighting air & friction from slowing you down. And, doubly obviously, this magic cruising number for best gas mileage depends on the coeficient of drag, weight, tires, etc.
The highest MPH we see here in NY is 65 on the quickway/thruway, of which I cruise 70-75 in at times,...I know down in NC/SC I-95 reaches 70mph, but otherwise it doesn't pay to cruise any faster, other than the fact that any street light totally outweighs the time you "bought" in going that fast.
-Dan, 7+ Years of driving Mr2's, Rx7's and Integra's without 1 ticket..
Old Sep 28, 2006 | 10:32 PM
65 is the limit here. I got pulled over cruise controlled at 60 because I was going to slow at 1am.
Old Sep 28, 2006 | 10:53 PM
00g's Avatar
00g
3250 at 65mph
3500 at 70mph
1994 GSR 4dr
Old Sep 28, 2006 | 10:58 PM
JCL's Avatar
JCL
lol too slow..
Old Sep 30, 2006 | 07:15 PM
Default Re: (JCL)
Thats what I said. I sorta laughed at him when he told me that. You could tell he felt kinda awkward that telling me 60mph was too slow.
