Transmission Q....Shift Arm Lock Bolt Removal
Does anyone know what tool is used to remove the lock bolt marked below. It is the same style as the manual tranny drain plug. Where you use a ratchet with no socket to remove it. Only this bolt is a different size than normal ratchets, looks like you use an allen wrench. I plan on going to buy some allen wrenches tommorow and i just wanted to make sure i got the right size....
so the interlock and shift arm assemblies can be removed along with the shift lever. Im taking the tranny cover off so i can replace the 5th gear syncro/hub/fork to fix the grind problem.
asubennett
Aug 21, 2003 05:14 PM
