seized caliper?
Old Sep 26, 2006 | 02:30 PM
Jay Blazed's Avatar
Default seized caliper?
damn grinding noise on drivers side wheel ... no prob pull off the wheel and brake pad tab is grinding .....no prob.....got new pads like last month and put them on
but now , using a crowbar i cant get the damn caliper back in .....it screws in i know...... but i think its seized ......i liquid wrenched it and gonna try again tomorrow
any suggestions.........might as well get new rear calipers .....prolly what it will come down to
but i just bought a townhouse and wanna look at my options
thanx
Old Sep 26, 2006 | 06:55 PM
95IRS's Avatar
Default Re: seized caliper? (Jay Blazed)
same thing happend to my friends integra rear caliper was seized your best off getting neww ones before the problems gets worse your break pads will be gone soon if there seized up that bad...
Old Sep 26, 2006 | 07:26 PM
Racermech's Avatar
Default Re: seized caliper? (95IRS)
Is this a front or rear???
Fronts push back in, rear screws (as you said) they are usually a bit hard to start then easy after that. I used a L time tool I had for something else.
You could try to break the bleeder screw to see if that helps, of course if you do that, and it moves you will have to bleed the system.
Old Sep 26, 2006 | 08:02 PM
harrykong's Avatar
the calipers should be removed and lubed prior to install =P this prevents it seizing. should be done each time brake pads are changed
Old Sep 27, 2006 | 03:27 AM
Jay Blazed's Avatar
damn harry
i dont think alotta people do that
lubed how the piston ?? does liquid wrench count??
you think taking somwhere reputable and saying " yea i just wanna change my rear pads"
maybe that tool just works bewtter then the crowbar...lol
Old Sep 27, 2006 | 03:40 AM
be.twenty's Avatar
i use a big *** prybar to turn the piston.. but there's actually tools made to do this. if you have trouble, you may be able to head out to the nearest auto parts store and rent one...
Old Sep 27, 2006 | 04:22 AM
VTteg's Avatar
I just had to replace my right rear siezed caliper and boy was it a pain with all the rust and corrosion from a 12 year old car. I ended up having to cut the bolts holding the ebrake bracket in place.
A 30 minute job ended up taking 3 hours. It sucked.
Good luck replacing yours.
Old Sep 27, 2006 | 09:34 AM
Jay Blazed's Avatar
new calipers all around is sounding really good right now
damn new house !
Old Sep 27, 2006 | 10:22 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (Jay Blazed)
i had one seize on me my man, its the worst sounding ride until you get it fixed. i just bought an OEM one and called it a day
Old Sep 27, 2006 | 10:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: seized caliper? (harrykong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harrykong &raquo;</TD></TR><TR><TD CLASS="quote">the calipers should be removed and lubed prior to install =P this prevents it seizing. should be done each time brake pads are changed</TD></TR></TABLE>
huh? Does the Helm's manual specify doing this?
I have never heard of having to disconnect brake lines and completely remove the calipers just when changing pads and/or rotors.
Old Sep 27, 2006 | 12:49 PM
Integritycaptain90's Avatar
yeah bro mine seized on me around jul. Couldnt screw back in so i replaced Oem, best to do both sides but nothing wuz wrong with the other side on mine. been fine ever since.
Old Sep 27, 2006 | 05:09 PM
gsr1289's Avatar
just my 2cent but it could be ur caliper bolt. see if you can get those out of the caliper with relative ease if not then replace that see if that helps they are only like 14 bucks or less at autozone or advanced.
Old Sep 28, 2006 | 11:24 AM
whitelightningls's Avatar
Default Re: seized caliper? (gsr1289)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr1289 &raquo;</TD></TR><TR><TD CLASS="quote">just my 2cent but it could be ur caliper bolt. see if you can get those out of the caliper with relative ease if not then replace that see if that helps they are only like 14 bucks or less at autozone or advanced.</TD></TR></TABLE>
this happend to me i thought the caliper was toast until i saw the little rubbers around the caliper bolts/slides were all torn up... there was no movement what so ever they were seized as hell... it took a torch, pliers and patience to get them free... so i got a new braket, rubbers and bolts/slides from Advance Auto for i think like $20 lubed it up good and haven't had a problem since... try pushing on the caliper while its on the car to see if there is movement if there is then this isn't the problem... all an all good luck i know this **** gets frustrating as hell
Old Sep 28, 2006 | 12:35 PM
gsr1289's Avatar
Default Re: seized caliper? (whitelightningls)
yeah man i wasnt very smart when it happened to me i just looked at it and was like its the caliper and went out and bought a new one then it still did it so i had to go out and buy the bolts oh well
Mr.Speed
Nov 13, 2008 05:40 AM
bbandco_keevee
Sep 4, 2007 01:43 PM
Merilious
Aug 2, 2004 11:39 AM
MechEng
May 10, 2004 05:12 AM
cccya
Oct 25, 2002 06:06 PM
