Should I get this balanced or not?
Old Sep 26, 2006 | 11:51 AM
sackdz's Avatar
Default Should I get this balanced or not?
B18C5 ~35kmiles. stock, ~9.1k redline. Honda challenge car.
Im rebuilding with pistons (stock) and bearings (Honda) only and keeping everything else [bottom end].
I can get the piston/pin/rod sets to within .5 gram by mixing and matching. Thats close enough, right?
Either way, where is the best place to remove material from the piston and rod?
I was thinking if needed just hitting the piston with an end mill on the underside of the face, and the rod along the side (concave portion) down the length and closest to the big end.
I was thinking I didn't need to do an all out full balance. The flywheel is exedy 12lb. and the crank pulley is a CTR.
Old Sep 26, 2006 | 08:54 PM
mgags7's Avatar
you can grind off the rod cap, the bottom part, without comprimising the strenght of the rod, i wouldnt grind down the main portion of the rod, as that may influence the integrity....
you can grind out anything inside the piston, just be careful around the skirt and the wrist pin sections....
Old Oct 26, 2006 | 08:10 PM
Chris F's Avatar
Default Re: Should I get this balanced or not? (sackdz)
Heaven forbid, you throw a rod through your block someone will notice that it isn't balanced!
I didn't think, at that redline, that OEM bottom end would be a weak link.
Hey man, hurry up and get it together, Wai is getting lonely, and I have no prospects of going back to H2. I might even find a B20 block for the ITR to get out of H2 and into H1 cheap.
jlfrnce
Sep 2, 2009 01:30 PM
lsvtecek18
Oct 19, 2006 05:47 PM
sackdz
Sep 25, 2006 08:10 PM
GarageAlchemist
Jul 16, 2006 10:54 AM
cnydc2
Apr 19, 2006 03:47 PM
