Car wont start! (I can't believe I'm posting this).
Old Sep 26, 2006 | 11:51 AM
KooK's Avatar
Mustang Sally
Default Car wont start! (I can't believe I'm posting this).
I don't have enough time to run through wires right now so here's what's going on, I got out of work a few nights ago, put the key in and *click.* I can hear the relay clicking from under the dash but my starter wouldn't engauge, wouldn't move period. So I jumped directly from the positive of my battery to my signal wire for the starter and she fired right up. Just to verify, when I got home I tested to see what voltage was coming out of that signal wire when I turned the key, it would read .01-.02 and fall back down each time I twisted the key, so obviously I've got almost zero current getting to the starter though that wire.
Anybody wanna answer it for me? I'm thinking either the wire is broken (which I find hard to believe), the relay is bad (which would be weird because I can hear it, it clicks hard and strong), or my ignition went bad (which would also be weird because it activates that relay). Am I missing something?
1995 GSR
Old Sep 26, 2006 | 11:59 AM
Miracle's Avatar
Default Re: Car wont start! (I can't believe I'm posting this). (KooK)
Sounds like a bad starter solenoid or a bad ground to me.
Old Sep 26, 2006 | 12:13 PM
KooK's Avatar
Mustang Sally
Default Re: Car wont start! (.Red.EM2)
The starter pulls almost as many ohms as the negitive cable itself, also with the fact that I can start it up by jumping it directly from my battery to the signal wire and have it work should mean the starter solenoid is ok.
Old Sep 26, 2006 | 12:17 PM
nitrofish420's Avatar
Default Re: Car wont start! (KooK)
I would say a bad ignition switch. Get a wiring diagram and check for power coming out of the ign. switch's start wire while turning the key to crank. If there's nothing there, make sure the switch is getting the proper supply power.
Old Sep 26, 2006 | 12:29 PM
KooK's Avatar
Mustang Sally
Default Re: Car wont start! (nitrofish420)
There's some good advice. Thank you.
Old Sep 26, 2006 | 12:48 PM
the_unknown's Avatar
GDD Lonely Krew
+2 on ign switch. it seems as though youve checked everything else so it should be the problem.
Old Sep 26, 2006 | 04:09 PM
KooK's Avatar
Mustang Sally
Default Re: (the_unknown)
Haha, I had the whole drivers side ripped out just tracing wires until I got to the starter relay, the bitchin plug fell out! How, you may ask? I have no clue! But she's secure in there once again and runnin good.
Weirdest thing, it was in there JUST enough to activate the relay, but wouldn't get any power to the starter.
slow_sihatch
16
Aug 4, 2015 04:35 PM
cksnah252
12
Sep 9, 2014 07:51 AM
slowassBubble
May 15, 2011 07:50 AM
Hanmin
Audio / Security / Video
12
Aug 8, 2010 04:18 PM
mtber
Jul 14, 2004 09:02 AM
