What cm clutch should I get?
Old May 1, 2002 | 08:46 AM
vtec69's Avatar
Default What cm clutch should I get?
Should i get a stage one, two, three, or four?
Here's a list of my mod
Ls/vtec
itr head with mild pp, crower403 cams, itr valves, itr intake manifold and throttle body, itr jdm header with 2.5in cat and 2.5 in custom exhaust, ls block slightly bored, ctr pistons, eagle rods, arp head bolts, and 2000 si tranny.
Old May 1, 2002 | 09:45 AM
vtecman's Avatar
Default Re: What cm clutch should I get? (vtec69)
If I were you I would get the stage 3 because its for heavy duty street and really good at the track, but it all depends on how you want your car to drive.
Old May 1, 2002 | 09:55 AM
BROOD's Avatar
Default Re: What cm clutch should I get? (jd90240sx)
I second that - Stage 3
Old May 1, 2002 | 10:11 AM
thejdmkid's Avatar
Default Re: What cm clutch should I get? (SLPR)
satge 3 an the aluminum flywheel for the best set up, or for price purpose get the satge 4 ,4 puck srung hub an the flywheel. just my two cents.
lowezz
Nov 20, 2006 06:52 AM
yellowbuffalo
Jan 22, 2004 12:42 PM
F1Spec
Sep 11, 2002 06:23 AM
vtec69
May 6, 2002 01:44 PM
