What brand DOT 3 Brakefluid for itr
Old Sep 26, 2006 | 06:21 AM
Dade-county
Guest
Posts: n/a
Default What brand DOT 3 Brakefluid for itr
Hello guys im new to this and wondering on something. What would you guys recommend for best compatible DOT 3 brake fluid.Sorry if this is a noob question i am new. I would also like to know what DOT 3 brake fluid you guys use. Thanks
Old Sep 26, 2006 | 06:25 AM
Willard's Avatar
Default Re: What brand DOT 3 Brakefluid for itr (Dade-county)
Honda sells brake fluid that will work.
If you would like something with a little more bawlz to it.... try 'ATE - Super Blue'.
Old Sep 26, 2006 | 06:27 AM
Dade-county
Guest
Posts: n/a
Default Re: What brand DOT 3 Brakefluid for itr (Willard)
thank you
Old Sep 26, 2006 | 06:31 AM
Willard's Avatar
if you are a balla... you can try 'Castrol SRF'.
Old Sep 26, 2006 | 07:56 AM
Shawn C's Avatar
In The Garage
i'm a fan of valvoline synpower fluid
Old Sep 26, 2006 | 08:09 AM
omiehomie's Avatar
Default Re: (Captain Fantastic)
hands down motul RBF is the ****
Old Sep 26, 2006 | 08:10 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">Honda sells brake fluid that will work.
If you would like something with a little more bawlz to it.... try 'ATE - Super Blue'.</TD></TR></TABLE>
Old Sep 26, 2006 | 08:59 AM
ITRacer121's Avatar
&lt;-- RBF 600 user for street and track driving
Old Sep 26, 2006 | 09:27 AM
Dade-county
Guest
Posts: n/a
Default Re: (ITRacer121)
i dont know what brand fluid is in the reservoir now. should i drain it and replace with new fluid or is it ok to just add this fluid straight in? thank you in advance.
Old Sep 26, 2006 | 09:42 AM
Willard's Avatar
Default Re: (Dade-county)
it might be the original fluid.... just suck most all of it out then top it up and bleed.
turkey baster = FTW
Old Sep 26, 2006 | 09:58 AM
walker111's Avatar
Default Re: (Willard)
Are you mechanically inclined? If not there is an awesome shop with smart peebles in the Orlando area. Little bit of a hike but the the peace of mind that someone competent is working on ur car is worth it!!!
407-657-6592
Old Sep 26, 2006 | 07:48 PM
nsxtasy's Avatar
H-T Order of Merit
If it's just for street use, any good quality DOT 3 or DOT 4 fluid is fine.
If it's for track use, you'll want to get the fluid with the highest boiling temperatures available. You can see a list of boiling points in this topic. Dry boiling point is relevant when the fluid is fresh out of the bottle. Wet boiling point is relevant after the fluid has been in the car for a while and had a chance to absorb moisture.
I use Motul RBF 600, much higher boiling points than most other fluids (it actually meets DOT 5 boiling point minimums, but it doesn't have the downsides of silicone-based DOT 5 fluid).
big_dong861
Jan 15, 2008 01:00 PM
undercoversi
13
Feb 18, 2005 05:54 PM
emotionisdead
May 27, 2004 06:45 PM
hoya_10fintec
18
Nov 12, 2002 11:15 AM
kenji
Jun 24, 2002 02:59 PM
