93 obd1 motor into 97 obd2 accord
Old Sep 25, 2006 | 10:43 PM
low97accord's Avatar
Default 93 obd1 motor into 97 obd2 accord
i swapped in 93 accord motor into my 97....the motor is in there fine...
but here is the problem, i see i am not geting any spark...
1. the 97 had an external distributor the 93 had internal (if i remember correctly)
would this make a difference....or could i still use my obd2 distributor? with external coil if u se the obd2 ecu
2. would it be easier if i use a jumper and a 93 accord ecu? (because i have one)
and if i do that would i need an obd1 distributor? would it matter if it were internal or external?
3. i know i need a new ignition but i can still crank the motor (With a screw driver or a key) would this make a difference?
i get the car to crank but it doesnt start...
basically im trying to figure how to get it started...i know that im more than likely its going to throw a cel...but i can live with that
but im sure somebody on here has done this swap b4 (thus the reason people pointed me here)
if you have let me know anything that needed to be rewired...and changes or whatever that needs to be done to get this started....this would be a big help.
Modified by low97accord at 12:02 AM 9/26/2006
Old Sep 26, 2006 | 04:11 PM
Default Re: 93 obd1 motor into 97 obd2 accord (low97accord)
any help?
Old Oct 19, 2006 | 12:06 AM
what happened to honda tech being the best place for mechanical info?
BoostedH
Jan 20, 2008 10:11 AM
wheelmaneg6
Aug 11, 2006 07:27 PM
duceducecord
Jul 1, 2006 09:27 AM
dblock
May 5, 2006 12:35 AM
Wherm5150
Mar 10, 2004 10:56 AM
