ecu pin ripped out ......help
I have a obd 1 harness in a 92 eg w/p28
In B plug harness.
a yellow/black wire got pulled out.
i think it is a1-a2
would that cause vtec to no work proplery. cause vtec stopped working. and got a 1000 rpm at idle, with ac on- or off?
I ecu pin is still lodge in harness and wire is exposed. how could i fix problem
In B plug harness.
i think it is a1-a2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetracerjoey210 »</TD></TR><TR><TD CLASS="quote">kool but what about fixing rip wire</TD></TR></TABLE>
Tape it? I don't get what you are asking. Do you just need to cover the exposed wire? If so then electrical tape should do it.
-Shane
-Shane
ok is there any pin that is not used in which i could use to re pin ecu harness, such as remove un/used pin and wire. and cut it off, solder and heat shrink un use wire.
then with the cut piece of wire. solder to wire that is ripped blk/yel...... heat shrink tape and problem solved i hope.
so can you let me know what wire in my ecu harnes that is not used.. that i could remove?
shivic
Jun 3, 2004 10:37 AM
