Gear Oil
Old Sep 25, 2006 | 08:39 PM
petty$rep's Avatar
Default Gear Oil
Hey everyone,
I just wanted to know if putting in 80W-90 gear oil into my transmission is bad for the transmission. Or would it actually help it out a little.
It is a manual tranny on a D16Z6.
Thanx
Old Sep 25, 2006 | 08:42 PM
sol2hatch's Avatar
Default Re: Gear Oil (petty$rep)
your just supposed to use regular motor oil in those trannies. Why do you want to use gear oil? I am pretty sure that wouldnt do any good. Use what you are supposed to, motor oil. I use Mobil 1 synthetic in mine, just cause that is what I run in my engine.
Old Sep 26, 2006 | 12:06 AM
Mista Bone's Avatar
D Tranny Guru
It will straight expletive UP your tranny. Gearoil won't flow enough to provide lubrication to the 5 rollers bearings under the gears.........
The resulting heat will melt the nylon bearing cages, then tranny is pretty much junk after that.
Gear oil
Can youn see the low fluid level also?
Motor oil
Old Sep 26, 2006 | 01:55 AM
sinister6's Avatar
Default Re: (Mista Bone)
it all depends i think? LSD tranny require much thicker rating..
Old Sep 26, 2006 | 05:21 AM
EG2Driver's Avatar
Default Re: (sinister6)
go to honda and get MTF, its the right stuff, no wondering or guessing.
Old Sep 26, 2006 | 05:36 AM
instructor74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">It will straight expletive UP your tranny. Gearoil won't flow enough to provide lubrication to the 5 rollers bearings under the gears.........
Gear oil</TD></TR></TABLE>
++2
Thank you for the post I am glad somone finnaly has a photo or 2 that show what putting gear oil will do to a honda tranmission.
Old Sep 26, 2006 | 06:32 AM
Eran's Avatar
HT White Ops
You're not supposed to put motor oil in honda trannies ... you can, but it's not the reccomended fluid.
Honda MTF ftw.
Old Sep 26, 2006 | 07:52 AM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister6 &raquo;</TD></TR><TR><TD CLASS="quote">it all depends i think? LSD tranny require much thicker rating..</TD></TR></TABLE>
Wrong. LSD equipped transmissions require nothing different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">You're not supposed to put motor oil in honda trannies ... you can, but it's not the reccomended fluid.
Honda MTF ftw.</TD></TR></TABLE>
Another myth. Honda did not even release MTF until about '98. Guess what they used before that?
EDIT: OP, just got to your dealer and get 3 quarts of MTF and be done with it. If you want to run Mobil 1 5W30/10W30 or even Dino oil that is fine too.
Modified by Mr Hammond at 12:06 PM 9/26/2006
Old Sep 26, 2006 | 08:48 AM
EX-T's Avatar
Default Re: (Mr Hammond)
I ran gear oil in my transmission for almost 2 years. The reason I put it in there was b/c the input shaft bearing was on its way out and by putting the gear oil in there it actually quietened down the bearing. I pulled that transmission out b/c I got another y8 that wasn't making any noise for FREE!
Old Sep 26, 2006 | 10:15 AM
Jimmy's Avatar
Global Moderator
Default Re: Gear Oil (sol2hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch &raquo;</TD></TR><TR><TD CLASS="quote">your just supposed to use regular motor oil in those trannies. Why do you want to use gear oil? I am pretty sure that wouldnt do any good. Use what you are supposed to, motor oil. I use Mobil 1 synthetic in mine, just cause that is what I run in my engine.</TD></TR></TABLE>
I would never reccomend run a synthetic oil in your tranny, but whatever floats your boat
Old Sep 26, 2006 | 10:48 AM
sol2hatch's Avatar
Default Re: Gear Oil (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
I would never reccomend run a synthetic oil in your tranny, but whatever floats your boat</TD></TR></TABLE>
Why not??
Old Sep 26, 2006 | 10:52 AM
Coach McGuirk's Avatar
who peed in my canteen!?
how does one check the transmission fluid and add more fluid is one question i've been wondering.
not trying to threa jack either.
Old Sep 26, 2006 | 02:41 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Hammond &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by Mr Hammond at 12:06 PM 9/26/2006</TD></TR></TABLE>
It's a myth that Honda reccomends Honda MTF as the prefered fluid for their manual transmissions? Gee, I guess my dealer lies to me. I know it wasn't ALWAYS used, but it's currently in use, and is the reccomended transmission fluid from Honda.
Old Sep 26, 2006 | 03:15 PM
thehatchninja's Avatar
most honda dealerships use the same 5w30 they have on tap for the engines.
Old Sep 26, 2006 | 03:36 PM
JDMFTW!!'s Avatar
Default Re: (thehatchninja)
true that
Old Sep 26, 2006 | 03:38 PM
evilsolb16's Avatar
Default Re: (JDMFTW!!)
all you have to do is look in tha manual it tells you to use 10w30 if not able to get honda mtf
Old Sep 26, 2006 | 04:09 PM
Mista Bone's Avatar
D Tranny Guru
Honda went to MTF after the addictives in the motor were changed. If anyone bother to look it up, Honda reccomends 10w30 SF/SG motor oil. But with the cleaner burning oil, less zinc was added. Take some motol oil, and some sulfer and zinc, sell it ai $7 a bottle.
V8 guys are having problems with camshaft wear because of the newer oil. Alot are running Shell Rotella for diesels.......
Old Sep 26, 2006 | 05:30 PM
sinister6's Avatar
I hope you referring to stock LSD tranny.. and i really wish your statment is true, cos this package is what i have now, and the price of these freakin oil is VERY expensive..
Old Sep 26, 2006 | 06:56 PM
Mista Bone's Avatar
D Tranny Guru
Nice package, but you can use Pennzsoil Synchromesh with the Kaaz. Like I stated above.
The KaazUSA shop car has about 45k miles on their 1611 LSD, I have about 60k miles. When I did order mind off here, I got a extra can of fluid, used both, then went to Synchromesh.
Think I paid $830 shipped with extra 2L of oil.
Old Sep 26, 2006 | 07:33 PM
bhed-w's Avatar
I've used 5w30 and Honda mtf and I can tell the difference.
Old Sep 26, 2006 | 07:39 PM
petty$rep's Avatar
Thanks for the pics Mr Bone
I have been running gear oil in my stock D16Z6 tranny for about 10,000 miles. Im going to change it to motor oil in the morning before I go to school.
How much damage do you guys think that 10k miles did to my tranny.
Im going to be pulling the transmission out in a couple of weeks to install new clutch, lightweight flywheel, and short shifter. What should I look for as far as damage.
Thanks
Old Sep 26, 2006 | 09:31 PM
blacksi93's Avatar
Default Re: (petty$rep)
HONDA MTF...nothing else
stop the maddness
Old Sep 26, 2006 | 11:43 PM
chrisw85's Avatar
I have tried Honda MTF, 10w30 motor oil, Redline MTL and right now I have Amsoil 5w30 Synchromesh MTF in there.
The amsoil has shifted the smoothest and crispest out of all of the other fluids for me. Second was the Redline MTL, then the honda, then regular chevron 10w30.
If you are going to use a 'gear transaxle oil' it must only be a GL-4 rated gear oil, as the additives in a GL-4 lube are safe for the metals inside honda transmissions. Don't use GL-5 in your transmission unless the transmission specifically takes it.
Old Sep 27, 2006 | 04:08 AM
del sol1658's Avatar
Default Re: (chrisw85)
Cant go wrong with honda MTF, its also made by IDEMITSU
Old Sep 27, 2006 | 07:46 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: (Eran)
It's a myth that Honda reccomends Honda MTF as the prefered fluid for their manual transmissions? Gee, I guess my dealer lies to me. I know it wasn't ALWAYS used, but it's currently in use, and is the reccomended transmission fluid from Honda.</TD></TR></TABLE>
It's all marketing. Yes most dealers do lie. Most "tell" you they are using MTF, but you usually get good old bulk 5W30 oil. Sorry to burst your bubble. MTF is nothing more then a non-detergent 5W30 oil w/ some additives. They just released a new MTF that will S/S the current stuff once it is gone. The original poster is talking about a 92-95 EX/Si tranny and back then MTF was not even around.
