whats the correct way to reset the tcu for 93 accord?
Old Sep 25, 2006 | 07:29 PM
primemal's Avatar
Default whats the correct way to reset the tcu for 93 accord?
whats the correct way to reset the tcu for 93 accord?.I keep getting code 7 and 8 which is the shift control solenoid a&b i have replace them with new ones and im still getting the code and tranny still wont change automaticlly and also still comes out slow from a stop,only way i can drive it its manually.
ps i have also taken the negative of the battery for a whole day and still same d4 light.i also disconnected the tcu and took it home and talked to it but it dint listen to me
Old Sep 26, 2006 | 08:03 AM
hondadude's Avatar
Default Re: whats the correct way to reset the tcu for 93 accord? (primemal)
removal of power should have reset the TCU.
A sign of a bad TCU is that the 'D4' or 'S' lite will come on and stay on when the key is turned to the on position.
Be sure the ground at the T-stat housing is clean and tight.
When you had the little talk to the TCU you might have hurt it's feelings LOL.
dsell
Jul 24, 2006 09:09 PM
idrc77
Apr 8, 2004 01:15 AM
jdowen2
Dec 28, 2002 07:41 AM
