E-brake and TCS light on. Why?
Old Sep 25, 2006 | 06:57 PM
ramman949's Avatar
Default E-brake and TCS light on. Why?
got a 2003 V6 EX accord and the the ebrake and TCS light recently turned on and it wont turn off. The rear pads are 4 months old. I changed the front ones today because they looked a little low, but not even near the wear indicator. I also checked the e-brake switch under the handle to make sure that wasnt broken. And finally I checked the fluid which is right at the top of the full mark. Yet the darn light stays on. I even pulled my negitive and reset the ECU and still its on. All wheel sensors are in place. What could be causing this? I also used one of those obdII ecu readers and it said I have no codes? But someone mentioned to me that I need a different code reading tool?
The ebrake will stay light up upon startup. Within 1 minute, the TCS light comes on. What the heck is wrong with my car?
Thank you in advance!
Ramman
Modified by ramman949 at 8:24 PM 9/25/2006
Old Sep 25, 2006 | 07:05 PM
BLKFLSH's Avatar
Default Re: E-brake and TCS light on. Why? (ramman949)
Just something I would check out. Jack up the rear and check to see if the ebrake is dragging. It may not be fully releasing. Don't know if this could also cause the TCS light to come on, but I guess it is possible. Good luck, finding the problem.
Old Sep 25, 2006 | 07:06 PM
Ross 2.0's Avatar
In a Junkyard near you.
you may have bad fluid level switch.. unplug it from the master and see if the brake light goes off.
If not you will need to take it by a dealer and have them pull the codes for you
Old Sep 25, 2006 | 07:45 PM
ramman949's Avatar
Default Re: (MooGoCow3)
Thanks for the reply. How do I c heck for dragging? I know how to change pads. But Im not sure I understand how to check for dragging. Would you please be so kind to educate me a little more?
Thank you,
Ram
Old Sep 25, 2006 | 07:47 PM
ramman949's Avatar
Default Re: (ramman949)
So unplug any power wire going into the m/c? If brake light goes off, then thats good. If not, take it in?
Thanks,
Ram.
YaMaJeSty
Honda Motorcycles
Feb 9, 2008 12:47 PM
justpassin
Sep 15, 2006 12:59 PM
PIC Performance
Jun 12, 2006 10:37 PM
effinnwackk
Nov 18, 2004 07:55 PM
Jetstream
Dec 13, 2001 08:20 PM
