96 -98 Power Window Conversion using 99-00 SI door harnesses and NO Floor Harness
Old Sep 25, 2006 | 04:10 PM
bzyrice's Avatar
Default 96 -98 Power Window Conversion using Door Harnesses and NO Floor Harness
Ok so use this chart if you DONT WANT TO use the Floor harness!! Since monicle's site is down alot lately I thought I would post this up.. for all those people wanting to tackle this (Monicle if you want me to take this off let me know.. I saved it to my computer one day just in case lol)
This is my setup:
(All parts are from a 99-00 Si)
- Power Window Regulators (Should be the same for years 96-00)
- Door Harness (96-00 harnesses have the SAME COLOR WIRES)
- Door Panels (Should be the same for years 96-00.. Color may differ)
if you DONT care about using the driver side to control the passenger side here is what you have to do: (again this is courtesy of monicle via old posts)
Driver Side (all wires come directly out of the plug connecting to the switch):
- Power -> Blue/Black Wire
- Ground -> 2 Black Wires
Passenger Side (all wires come directly out of the plug connecting to the switch):
- Power -> Green/Black Wire
- Ground -> Blue/Yellow and Blue/Orange Wire
note: I would do this first before connecting driver side to passenger side and running/hiding all the wires to make sure the regulators work. This will save u some time from trying to diagnose a wiring problem when in fact it is the regulators that are busted.
If you DO care about using the driver side to control the passenger side here is what you have to do:
- Connect the Blue/Yellow and Blue/Orange Wire from the driver side switch to the passenger side switch.
- Connect the Green/Black wire from Driver side to Passenger side (So the passenger side Green/Black wire is connected to the power source AND the driver side door)
some notes:
- MAKE SURE YOU GROUND THE WIRES GOOD (I was having problems because I did not have a good Ground!!! I ended up grounding the 2 black wires to the screws that hold the regulator in)
- per Monicle use a 20 amp fuse if you connect directly to the battery (this is how I did it the first time.. only problem is that the power windows will ALWAYS work. So you might want to get power from something else that turns on when the key is on.. I redid my wiring and connected all wires that needed power to the cigarette lighter (white wire) I also changed the fuse under the dash for the cigarette lighter to a 20 amp fuse(it is the 5th fuse from the left on the top row). I had the 10 amp fuse in there but the fuse blew.. I Have had the 20 amp fuse in for a week and its ok)
(for those of you who say.. GET THE FLOOR HARNESS.. please do not comment.. I do not want to spend another 100.00 for this conversion)
BTW, Doing it this way only took me 3 hours for wiring.. just cuz I had to figure out how to get the driver side to control the passenger side.. and I also tried to make the wiring as clean as possible.. plus it was a pain in the a$$ to get the wires from the door to the cabin.. If i did it again, it would probbaly only take me an hour for wiring. So doing it this way saves someone from tearing up the whole car and using the wiring harness.
PLEASE BUMP IF THIS HELPED U!!
Modified by bzyrice at 9:43 PM 9/27/2006
Modified by bzyrice at 9:44 PM 9/27/2006
Modified by bzyrice at 9:48 PM 9/27/2006
Modified by bzyrice at 4:06 PM 10/2/2006
Modified by bzyrice at 4:11 PM 10/2/2006
Modified by bzyrice at 4:18 PM 10/2/2006
Modified by bzyrice at 4:28 PM 10/2/2006
Modified by bzyrice at 4:32 PM 10/2/2006
Old Sep 25, 2006 | 04:51 PM
GBRacing's Avatar
I can't help you but good luck with it. FYI - I'm a new proud owner of an GP White EK
Old Sep 25, 2006 | 05:00 PM
bzyrice's Avatar
Default Re: (GBRacing)
haha no way! what happened to ur eg?
oh nm i jsut saw ur sig lol ..
Old Sep 26, 2006 | 06:41 AM
bzyrice's Avatar
tttt
Old Sep 26, 2006 | 08:35 AM
alacard's Avatar
bump for a man who is doing something that i will probably be doing in the future ^^
Old Sep 26, 2006 | 09:05 AM
b18c4door's Avatar
Not to jack: I was planning on using 96-98 civic ex parts for it as I thought they would be close to the 96 hatch which is what we have.
Whdy did you use SI parts? Just want to make sre before I buy something... I suppose I need door panels as well, right?
Old Sep 26, 2006 | 04:35 PM
bzyrice's Avatar
Default Re: (b18c4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c4door &raquo;</TD></TR><TR><TD CLASS="quote">Not to jack: I was planning on using 96-98 civic ex parts for it as I thought they would be close to the 96 hatch which is what we have.
Whdy did you use SI parts? Just want to make sre before I buy something... I suppose I need door panels as well, right?</TD></TR></TABLE>
I got the SI parts because that was the car i found with the parts.. i asked monicle and he told me that the door harnesses are the same so that part doesnt matter..
yes u will need door panels unless u custom urs now.. but that would be soo ghetto..
monicle is helping me through pm.. I will post anything i find out in this thread..
Old Sep 26, 2006 | 05:06 PM
1slowEK's Avatar
Default Re: (bzyrice)
dude my **** still dont work! lol i got them to roll up and down... but i cant get the drivers switches to work the passenger window...
good luck and bump to you!
Old Sep 26, 2006 | 05:10 PM
bzyrice's Avatar
haha seriously?!
At least u got them to work like that!! u got a pic of the wiring u did?! Im still trying to figure out why mine isnt working AT ALL.. lol
Old Sep 27, 2006 | 10:43 AM
bzyrice's Avatar
tttt .. i have time to work on this tonight and need some other ideas.. thanks!
Old Sep 27, 2006 | 11:02 AM
CTRwannaB's Avatar
mine worked out fine but then again i had the floor harness
btw my pwr locks don't work tho
Old Sep 27, 2006 | 12:36 PM
bzyrice's Avatar
yah i dont want to find a floor harness..
Old Sep 27, 2006 | 05:31 PM
bzyrice's Avatar
so i figured out what it was.. lol
Monicles chart WORKS..
I feel like a dumba$$ admitting this.. but I just didnt ground the wires that well.. this time around i grounded every wire to its own bolt.. and it worked!! WOOHOO!! I got each side to work on its own..
Now I just need to get the driver side to control the passenger side.. haven't tackled that yet.. Ill do that tomorrow since Im too lazy to do it today.. lol .. thanks monicle!!
Old Sep 27, 2006 | 05:47 PM
bzyrice's Avatar
updated the first post for any one who is too lazy to read all the posts lol ... i will continue to update it because I know I still had alot of questions when i started to do the conversion..
Old Oct 2, 2006 | 12:25 PM
bzyrice's Avatar
BUMP ..
I FIGURED OUT how to control passenger side to driver side!! I updated Original post!
Old Oct 2, 2006 | 08:18 PM
dmefb18's Avatar
up
Old Oct 7, 2006 | 09:38 PM
Sleepercivic2's Avatar
Default Re: 96 -98 Power Window Conversion using Door Harnesses and NO Floor Harness (bzyrice)
Thanks for the info..saved me a ton of time....BUMP
Old Oct 8, 2006 | 07:08 PM
bzyrice's Avatar
no problem
Old Oct 11, 2006 | 11:27 PM
vroomvroomcivic's Avatar
good job man, i plan on doing this one day, curious where is monicles site? just wanted to see what the floor harness looked like JUST in case i can pick one up.
Old Oct 12, 2006 | 07:14 PM
bzyrice's Avatar
pm monicle.. he is still on here.. tell him i referred u.. btw.. its alot easier without the harnes.. lol.. but its still up to u..
Old Oct 15, 2006 | 12:58 PM
Uneekpinoysk8er's Avatar
bump.. good info
Old Oct 15, 2006 | 01:23 PM
ZZT231's Avatar
Default Re: (Uneekpinoysk8er)
This is why you buy an EX or Si in the first place.
Old Oct 15, 2006 | 01:24 PM
bzyrice's Avatar
Default Re: (ZZT231)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZZT231 &raquo;</TD></TR><TR><TD CLASS="quote">This is why you buy an EX or Si in the first place. </TD></TR></TABLE>
yah but too bad.. the hatches over here in the US didnt have any of the power options!
Old Oct 15, 2006 | 01:31 PM
ZZT231's Avatar
I know, that's why I got rid of my EK hatch. I liked my EX coupe much better. I totalled up the full cost of making the hatch equal to a EX with power options, it was better to move on to new car!
Old Oct 15, 2006 | 03:57 PM
bzyrice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZZT231 &raquo;</TD></TR><TR><TD CLASS="quote">I know, that's why I got rid of my EK hatch. I liked my EX coupe much better. I totalled up the full cost of making the hatch equal to a EX with power options, it was better to move on to new car!</TD></TR></TABLE>
ah.. i c.. well this is for those who have hatches or non ex civics.. i like my hatches better cuz i can fit more stuff in them .. cant fit anything in my s2000 lol..
