must you use a block guard to bore and hone?
ok heres the deal i just started to build my first motor in my engine building class at my school. its a 1st gen b16a and im going all motor. my cylinder bores are out of round so i have to go .20 over and my shop teacher is saying that i have to run a block guard to bore and hone my sleeves or any open sleeve motor reguardless if its na or fi. i have never heard that people have to use a block guard to bore and hone. and my questioon is are there people out there that have succesfully bored and honed there motors without a block guard. tell me some opinions.
there has to be someone out there that has bored and honed a b-series engine. if you have did you or did you not use a block guard?
No u do not need a block guard..Theres plenty of ppl not using a block guard..like me for instance..Im bored .20 over on a b18c and no block guard...Whoever had the motor before me put a block guard in and i had some overheating issues with it in so i removed it before assembly.
Your shop teacher needs to go back to school. I have run as big as an 86.5mm bore with no block guard. No sealing issues either-my machinist is Dan Benson and his work is second to none.
your shop teacher is correct, if using a blockguard, you need to install it first then bore and hone since it can shift the sleeve slightly
hold on i understand that IF i want to use a block guard i need to bore and hone after i put the block guard in. BUT i dont want to use a block guard. my teacher is telling me that IF i want to machine the block i need use the block guard. its the other way around.
please does anyone have any info on block guards?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djphonics »</TD></TR><TR><TD CLASS="quote">Sounds like some straight up B.S. to me. Does your shop teacher have any experience with open deck motors?</TD></TR></TABLE>
yes he says that he has put honda blocks on his boring machine and it distorted the cylinder walls. but i have heard from a lot of guys that have gone .20 over and they havent used a block guard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">Your shop teacher needs to go back to school. I have run as big as an 86.5mm bore with no block guard. No sealing issues either-my machinist is Dan Benson and his work is second to none.</TD></TR></TABLE>
but i dont think you ran stock sleeve 86.5 mm bore. there would be no cylinder wall left if it was stock sleeves
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benmyfriend »</TD></TR><TR><TD CLASS="quote"> if you want to machine stock sleeves do you have to use a block guard?</TD></TR></TABLE>
No.
No.
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
no is the answer however if you are going to use a block guard make sure that it is installed when the boring is done ..... again NO you absolutely do not need a block guard.
im sorry for beating this thread to death but does anyone know why my teacher is distorting sleaves when he doesnt use a block guard? or is there some type of trick to machining honda blocks? thanks
You alternate bores, 1=4=2=3 do it in 2 cuts, use lots of cutting oil, and hone it in 3 steps using the same 1-4-2-3 steps. It ain't a Chebby. Temperature matters.
Now if he is talking honing plate, I have one I will sell you. They are expensive.
