Bleeding brakes on 92 with ABS
Old Sep 25, 2006 | 02:20 PM
migg_243's Avatar
Default Bleeding brakes on 92 with ABS
I have been told you need special tools. Is this ture, if so what are they?
Car has rar disc brakes and they are both dragging left side is the worst. Any ideas?
Thanks
Old Sep 25, 2006 | 02:37 PM
hondadude's Avatar
Default Re: Bleeding brakes on 92 with ABS (migg_243)
Bleed the brakes in the normal manner. The ABS is not in play unless there is a wheel lock up. As far as the brakes dragging; be sure the slider pins are lubed and working, beyond that the calipers might be sticking and need replaced.
Old Sep 25, 2006 | 03:39 PM
JimBlake's Avatar
Default Re: Bleeding brakes on 92 with ABS (hondadude)
And sometimes dragging brakes are caused by the pad's steel backing plates being wedged too tightly in the caliper bracket. Maybe corrosion has tightened up their fit?? Check that when you're in there checking the other stuff hondadude mentioned.
kit50si
13
Nov 18, 2006 06:06 AM
Steven5210
Honda Civic (2006 - 2015)
Jun 25, 2006 12:57 PM
vtecrx
Acura TL, RL & ZDX
Jul 25, 2001 04:04 PM
vtecrx
Jul 18, 2001 07:32 PM
