Knock Sensor...what size socket??
I just got my knock sensor, and I was going through my sockets, and I can't find a socket that fits. I would assume it is metric and not standard, but I could not find my 32 mm or 36 mm socket(use these for my axle nuts). So I'm searching, and I try a 1" and it is too small, I then try a 1 1/8" and it is too big, so what size socket should I be using? It looks to be a special shaped one, but I am not sure...
pretty sure its 1 1/16", my buddy had a socket this size and it was perfect fit.
on a side note, how much did you pay for your sensor? and what was your reason for replacing it? my car still has CEL 23 and im waiting on a new sensor, hoping that fixes it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmastermindxx »</TD></TR><TR><TD CLASS="quote">pretty sure its 1 1/16", my buddy had a socket this size and it was perfect fit.
I bought a used one, and it was for 35 bucks. I am throwing a code 23, and I hope this makes it go away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH »</TD></TR><TR><TD CLASS="quote">24mm if memory serves correctly.</TD></TR></TABLE>
I tried my 19mm socket, and it seemed really small. But I will try it out. I'll take it to autozone and try it out. Thanks!
</TD></TR></TABLE>I bought a used one, and it was for 35 bucks. I am throwing a code 23, and I hope this makes it go away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmastermindxx »</TD></TR><TR><TD CLASS="quote">its closer to 27mm, im pretty sure its the 1 1/16", not special shaped or anything.</TD></TR></TABLE>
1 1/16 is roughly 27mm(26.9875mm to be exact)
i guess I just need to take it up there...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmastermindxx »</TD></TR><TR><TD CLASS="quote">yea its the 1 1/16" i just checked. its a pretty big socket
post if your CEL goes away or not when you get it in
will do. limp mode sucks
</TD></TR></TABLE>will do. limp mode sucks
I just replaced my knock sensor no more then a few months ago. I had to go out and buy a set of the massive sockets just for it. Its the largest socket in the set which is 24mm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH »</TD></TR><TR><TD CLASS="quote">I just replaced my knock sensor no more then a few months ago. I had to go out and buy a set of the massive sockets just for it. Its the largest socket in the set which is 24mm. </TD></TR></TABLE>
ok, ill try both @ the store
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 »</TD></TR><TR><TD CLASS="quote">iirc obd1 ks =27mm </TD></TR></TABLE>
thanks Steve-o...
I was doing the conversion math just am inute ago, and 24 mm = .98 inches(approx.), and I tried a 1" socket, which was too small...so I knew it couldnt be 24 mm.
But thanks for the help!
thanks Steve-o...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever »</TD></TR><TR><TD CLASS="quote">well i searched the helms in hopes of finding a socket size.....nothing...but i did get a tq spec - 23ft-lbs...
good luck, and if i remember right....steveo is right....</TD></TR></TABLE>
Thanks matt!
Thanks matt!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever »</TD></TR><TR><TD CLASS="quote">good luck, and if i remember right....steveo is right....</TD></TR></TABLE>
x2
27mm = almost exactly 1 1/8"
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmastermindxx »</TD></TR><TR><TD CLASS="quote">x2
27mm = almost exactly 1 1/8"</TD></TR></TABLE>
actually, it is almost 1 1/16.
1 1/18 is too big, b/ I tried it.
on a side note, it is a 27 mm, I took the sensor to the parts store, was looking threw sockets, and had to get a deep well 27, fit like a glove. So, I get home, and I just up the car, and get under there. Let's just say, honda put this sensor in the worst possible position. That bitch was so hard to get to. And trying to use a 1/2 drive wratchet doesnt help either. But after a while, I get it off, and the new one on. Made sure to plug it up correctly, the plug with just 1 wire. I then reset my ecu for 30 seconds...
Go fire her up, no CEL. So Im like, ok, I take her for a drive. I wait until she warms up a little bit, and then I get into her, hitting vtec, going through the gears. Still no CEL. Well on the way home, Im driving pretty conservative, I shift at 4krpm, and go to 4th. and BAM, CEL. I was like expletive!!!! God Dammit!!
So I get home, and I was talking to MAtt(bb4ever) online on AIM. ANd he was trying to hepl me figure out my problem. I was going to check if the wire was grounded out. B/c that could be a very good possibility. Also, my sensor could be bad, but it looked damn good. No cracks on the plastic plug, nothing. Last resort, iis a bad ecu.
Well, we are chatting, and he asked me if I drove the car before the swap. And I said, yes, it had the f22 in it before I swapped. Well, He asked what harness i was using, I said h23. Well, come to find out, the knock sensor was never reaching the ecu.. It was reaching the shock tower and all, b/c of the h23 harness, but from the shock tower to the ecu, there is no wire going to the ecu for the knock sensor. I looked at my ecu plug, and sure enough, right there in pint D3, there was NO wire.
How stupid am I ? I probably just bought another knock sensor for nothing.
yea i meant 1 1/16", that was what i said earlier anyway
so do you have to run a wire for it now? i guess the CEL comes up just because its reading no KS there... i swapped busted H23 with another, so im pretty sure the wire is still there.
wanna sell one of your KS's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmastermindxx »</TD></TR><TR><TD CLASS="quote">yea i meant 1 1/16", that was what i said earlier anyway
yeah...ill sell you my spare. since both of them look to be good.
</TD></TR></TABLE>yeah...ill sell you my spare. since both of them look to be good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever »</TD></TR><TR><TD CLASS="quote">thats true...and after removing the obd2 one with a 24, 2 yrs ago during my swap i broke the plastic part damn obd1 sensor with teh too small 24mm socket without even realizing it.....dammit.</TD></TR></TABLE>
Thats why i used a big *** deep 24mm
i had to make 3 trips to sears before i got the damn right socket size. lol
nighttrain33
Jun 6, 2017 09:02 PM
GaAr@
Jul 19, 2010 07:44 PM
