Secondary Butterflies
Old Sep 25, 2006 | 01:33 PM
friday86's Avatar
Default Secondary Butterflies
I need a "Air Intake Bypass solenoid (secondary butterflies)" i'm not 100% sure what it is or what it looks like, but I guess it's missing from my h22... where can I find one ASAP!!! Thanks!
Old Sep 25, 2006 | 03:02 PM
hondadude's Avatar
Default Re: Secondary Butterflies (friday86)
can you clarify your problem? the description of your problem is as clear as mud.
Old Sep 25, 2006 | 03:55 PM
JimBlake's Avatar
So your H22 intake manifold has the IAB system, but it's missing the solenoid valve? Dealer, or your favorite mailorder place, or your favorite junkyard??
Do you have the vacuum storage bottle & it's check valves to go with that?
What year Prelude did your engine come from? Check hondaautomotiveparts.com for parts drawings of that system.
Old Sep 27, 2006 | 07:55 AM
friday86's Avatar
Default Re: Secondary Butterflies (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">So your H22 intake manifold has the IAB system, but it's missing the solenoid valve? Dealer, or your favorite mailorder place, or your favorite junkyard??
yes... the mechanic said that i'm missing the little black box that's supposed to be mounted on w/ the engine... so it's missing and i'm guessing it's called the secondary butterflies? or Air Intake bypass solonoid? Its from a 93 Prelude.. jdm engine... auto engine w/ manual tranny... I was goin to call the dealer, but I heard it was gonna be expensive! and I'm not sure what it looks like so i cant go to a junkyard.. . thanks for the info!!!
Bump for more info!
Old Sep 30, 2006 | 05:58 PM
JimBlake's Avatar
I tried looking up parts pictures & didn't have much luck. Apparently Preludes are different than my Integra.
Mine had a vacuum bottle mounted under the manifold, with a check valve & a solenoid valve. Technically, the secondary butterflies are just one part of the 'intake air bypass' system.
Hopefully someone who has the Prelude version of that IAB system will come around & clarify this.
Old Oct 1, 2006 | 08:16 PM
BlUAc's Avatar
I have two one for a accord f22a6 and a jdm h22 both the black box are the same just a lil different in shape the accord one is more square and the h22 is a lil more rounded at the sides dont no bout the gsr though and they both were under the im solenoid valve was there put I did not see a check valve
Old Oct 2, 2006 | 04:14 AM
TouringAccord's Avatar
H-T Order of Merit
When I was looking to put a H23 IM on my F22B1, I bought a H23 IM and was then looking for that same black box. I couldn't find a picture of it either but I was finely able to find it under the "Install Pipe-Tubing" listing on HAP and SLHonda. Here's a diagram of what your looking for...
#12 Vacuum Tank 36361-PT2-014
#10 Bypass Control Solenoid Valve Assembly 36163-PT2-004
The Bypass Control Solenoid Valve Assembly is mounted onto the Vacuum Tank.
Those two parts are quite pricey to buy from the dealer.
I have one of those black boxes and solenoids that I'm selling with my H23 IM. I ended up finding it for sale in the classifieds on this site.
If you would like to see an actual picture of the tank and solenoid I can take a picture and post it later today when I get home from work.
Old Oct 2, 2006 | 09:02 AM
friday86's Avatar
Default Re: Secondary Butterflies (TouringAccord)
thanks for the info...
Old Oct 2, 2006 | 09:27 AM
Hawkze_2.3's Avatar
Here's pics I had of all the IAB parts--
Old Oct 2, 2006 | 09:41 AM
friday86's Avatar
Default Re: Secondary Butterflies (Hawkze_2.3)
Thanks for the pics... very helpful and noticable... for sure, that wasn't on my intake mani...
racetowin
Apr 2, 2006 02:36 PM
SoOHiGH
May 28, 2005 05:29 PM
teawoboba
Oct 29, 2004 11:08 PM
blackedoutcivic
Aug 21, 2004 06:11 PM
:mR. PotAtO heaD:
Jun 17, 2004 03:28 PM
