h22 type sh into 95 obd1 accord
hey there,,, i have a 1995 honda accord lx coupe and i just found a type sh h22 motor for a real good deal, but im Hesitant about getting it because i hear that converting it from obd2 to obd1 with the injectors and from the external coil to the accords stock internal coil..so heres the question.. to deal with the type SH h22's external coil , do i have to re-wire my harness or do i just get a obd1 distributor? along with obd1 h22 injectors... i will be running a obd1 p13... all help will be great!
This is in the Accord FAQ:
H22 swap into 5th gen
The swap is easier if you avoid the SH motors, due to the block differences regarding the way it mounts to the tranny. The Prelude SH has the ATTS, which necessitates the block differences. There will be some customization involved if you try to bolt that motor to any other transmission.
. o 69 o .
Jan 16, 2004 09:54 PM
