95 ACCORD OBD1 H22a irratic IDLE PROBLEMS, CALLING ALL H22 ACCORD OWNERS FOR HELP !
Old Sep 25, 2006 | 11:53 AM
bpot555's Avatar
Default 95 ACCORD OBD1 H22a irratic IDLE PROBLEMS, CALLING ALL H22 ACCORD OWNERS FOR HELP !
My idle is crazy, it jumps every second from 1500 to 800 and it very jerky in low gear.
The MITV works correctly I checked it out. IF you cover the IACV (top hole in the tb) the idle drops down to 800 again no jumping.
I tried to just disconnect the wire from the IACV (thing thats on the front of the intake manifold). It was real hard to start, idled good, but kept stalling when I was trying to drive. DOES ANY ACCORD H22A owner HAVE A GOOD PICTURE ON HOW THIS THING IS SUPPOSED TO BE HOOKED UP? OR CAN ANYONE WITH AN H22 AT LEAST PROPERLY EXPLAIN WERE THE TWO IACV HOSES HOOK UP TO?
PLEASE HELP !!!
Old Sep 25, 2006 | 01:31 PM
alterdcreations's Avatar
Default Re: 95 ACCORD OBD1 H22a irratic IDLE PROBLEMS, CALLING ALL H22 ACCORD OWNERS FOR HELP ! (bpot555)
check yout throttle body. there is a thermel valve that causes that problem.
block the bottom hole in your throttle body and see is the problem stoms. If it does then you have to unbolt the idle valve from underneath the throttle body, dissasemble the side with the screw bolts(not the side with just screws) and twist the plastic center all the way down.
the valve is located on the under side of yout throttle body and has coolant lines also connected to it
Old Sep 25, 2006 | 03:58 PM
bpot555's Avatar
Default Re: 95 ACCORD OBD1 H22a irratic IDLE PROBLEMS, CALLING ALL H22 ACCORD OWNERS FOR HELP ! (alterdcreat
i already did that, NEED HELP WITH THE VALVE i AM POINTING AT IN THE PIC !
Wolfmonkey
Mar 1, 2018 08:17 PM
pontiacformlt1
Nov 1, 2009 08:15 AM
koreachangsu
Oct 11, 2006 12:00 PM
auto-e-shop.com
Jul 26, 2005 04:13 PM
