Should I even bother tunning?
I'm a Jackass
From: who knows.. the shadow knows, CA, United States
Well I just recently got an SMSP header for my H22A Euro R motor. Im wondering if I should even bother tuning it. I use crome on a chipped p28. How much of a difference am I really looking at. Should I bother with a 150$ buck an hour tune?
after all my tuning and converting to obd1 I made
184whp 152ftq without the header pretty much intake crappy 2.25 exhaust obd1
my dads also giving me **** about ( why bothers ) so any excuses would be a great help.
Any help would be good.
Thanks
p.s. I would have posted in performance but they wont let me
Modified by WeekH22#2 at 3:52 PM 9/25/2006
Modified by WeekH22#2 at 3:54 PM 9/25/2006
Thanks
So you've already tuned your engine, and have since installed the SMSP header?
edit: I used to be running a hondata setup that had someone else's bolton H22 tune on it. Presumably on his engine it was a nice 13:1 or so line across the board.
This is what Dave's header did to that tune.
Your new header is flowing a LOT of air, especially up top. If you were running a stock ECU I wouldn't worry too much since they run very very rich in the top end, but if you were tuned to a nice flat A/F (ie, with less room for error) I'd consider fixing it up a bit.
Modified by A Blue Lude at 12:31 PM 9/25/2006
you could get away with out a tune. but you spent the money on the header.....get the tune to go with it. those headers flow really well so it should be worth your money.
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
yes the tru test of a header is in the AFR curve ... a better header should make afrs leaner because the header is working better than the previous one and actually using up all of the fuel that the ecu is supplying. getit tuned for sure!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WHITFIELD-TUNED »</TD></TR><TR><TD CLASS="quote">yes the tru test of a header is in the AFR curve ... a better header should make afrs leaner because the header is working better than the previous one and actually using up all of the fuel that the ecu is supplying. getit tuned for sure!!!!</TD></TR></TABLE>
uh oh, another reason not to pay attention to HP
I'm a Jackass
Hmm also the timing was all the way retarded when I got it tuned. Will I gain more power now that the timing is corrected with this header, and new tune? I dont feel a difference really with the SMSP
where is my 20whp
where is my 20whp
DYNO-PRO
u will feel a difference
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">
uh oh, another reason not to pay attention to HP </TD></TR></TABLE> obviously not ... with correct afrs and ignition timing .... HP will follow i am willing to bet that this particular vehicle went lean after the header was installed ... hich by tuning the AFR back to where it should be the HP will also increase
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WHITFIELD-TUNED »</TD></TR><TR><TD CLASS="quote">u will feel a difference
Groovy then i'll take it back to upland soon for retuning.
obviously not ... with correct afrs and ignition timing .... HP will follow i am willing to bet that this particular vehicle went lean after the header was installed ... hich by tuning the AFR back to where it should be the HP will also increase </TD></TR></TABLE>
Im not sure if it went leaner at whitfield or not.
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch »</TD></TR><TR><TD CLASS="quote">probably suck because you will be ripping around town
get that bitch tuned </TD></TR></TABLE>
yeah I do get on it quit a bit :D. I mean after the tune hopefully I can get at least 200 to the tank on the street. Right now its like 170 if I drive nice
