b16a swap ?
Old May 1, 2002 | 04:33 AM
slowpokesi's Avatar
Default b16a swap ?
well my motor should be showing up soon and im going to have a little bit of extra cash. so i was thinking about changing out the head gasket! do you think this is necessary? what kind should i get oem, aftermarket, what brand? my future goals about a year away are to run boost. in the mean time i might spray a 50 shot.
shopping list so far: is there anything that i should add?
new radiator hoses
rear main seal
valve cover gasket, spark plug grommets
new plugs
magnecore plug wires
new cap and rotor
hasport adjustable linkages
place racing mounts
oem exhaust manifold gasket
timing belt
water pump
oilpan gasket - i plan on taking the oilpan off and cleaning it and putting a new gasket on.
im not sure if the exhaust manifold will fit so i saved the one off my 00 si
Old May 1, 2002 | 06:16 AM
slowpokesi's Avatar
Default Re: b16a swap ? (slowpokesi)
NOBODY KNOWS?
Old May 1, 2002 | 06:53 AM
K_1's Avatar
K_1
get a spoon head gasket, it read that it raises the compression up a little, just A little.....
Old May 1, 2002 | 09:53 AM
Malgerus's Avatar
Check your engine (when you get it) for signs of any oil leaks around the gasket area. If there are none, don't bother. on the other hand, it's easy when the engine is out of the car.
1990 CB7
Feb 27, 2017 11:40 AM
HiGhGuY
Jul 30, 2014 10:13 AM
wittynamessuck
Honda Civic (2001 - 2005)
14
Oct 27, 2011 07:28 AM
prostreetonline
May 3, 2006 04:36 PM
rasta420
May 15, 2003 07:05 AM
