Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
06 crv rubbing or sqeak when turning
Old Sep 24, 2006 | 11:30 PM
mikesterny's Avatar
Default 06 crv rubbing or sqeak when turning
my girls 06 crv makes a weird sqeakin or rubbin noise when she makes a sharp turn? anyone got a clue and what is the factory tire specs? thx
Old Sep 25, 2006 | 08:32 AM
Ross 2.0's Avatar
In a Junkyard near you.
Sounds like the rear diff fluid needs to be changed (dual pump fluid)
be sure the tires are all the same (tread and 29 psi pressure) or the 4wd system will be constantly active and cause the fluid to break down faster.
Old Sep 27, 2006 | 12:46 PM
Honda_V_2000's Avatar
Default Re: 06 crv rubbing or sqeak when turning (mikesterny)
my 2000 did the same thing and it turned out to be a problem with the rear diff, have it checked for fluid level. ALso the front drive line out of the tranny was a problem.
hope that helps
juevi
11
Aug 16, 2015 03:09 PM
transitions
Honda CR-V & Element
Nov 16, 2010 12:22 PM
lmccammon
Acura TL, RL & ZDX
Jul 21, 2005 09:37 PM
lmccammon
Feb 16, 2005 03:52 PM
enthusiast128
Jan 29, 2002 01:16 AM
