Will JL monoblock power 2 subs?
Old Sep 24, 2006 | 10:29 PM
N1NjA TuRtLE's Avatar
Default Will JL monoblock power 2 subs?
I plan to put a system in my car, and i was wondering whether the JL Audio MONOBLOCK E1200 amplifier will be able to power my 2 JL audio subs, i don't know the models but i think they're W3v2 and i don't know how much watts they're pushing.
Old Sep 24, 2006 | 11:17 PM
turboekcivic's Avatar
Default Re: Will JL monoblock power 2 subs? (N1NjA TuRtLE)
yeah youll be fine running 2 subs with that amp
Old Sep 24, 2006 | 11:19 PM
Default Re: Will JL monoblock power 2 subs? (turboekcivic)
okay cool, i'd thought so too because they're just 10 inch, and pretty old models, i'd not think they be running that much wattage but just to be sure the specs of the AMP: 120 W RMS x 1 @ 4 ohm (12.5V);
200 W RMS x 1 @ 2 ohm (12.5V)
Old Sep 25, 2006 | 11:30 AM
fcm's Avatar
fcm
Old Fart
As long as the 2 subs are 100W continuous, [RMS] 4 ohm VCs it will work no problem, wire in parallel for a 2 ohm load and your good to go, if however they are more then 100W subs, or they can't be wired for a 2 ohm load, [2 or 8 ohm VCs or DVC 4 ohm] then you will be under-powered, and although that will still work, you will have to be careful not to over-drive the amp, [into constant clipping] as that will damage the VCs. 94
Old Sep 25, 2006 | 05:21 PM
Default Re: Will JL monoblock power 2 subs? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> As long as the 2 subs are 100W continuous, [RMS] 4 ohm VCs it will work no problem, wire in parallel for a 2 ohm load and your good to go, if however they are more then 100W subs, or they can't be wired for a 2 ohm load, [2 or 8 ohm VCs or DVC 4 ohm] then you will be under-powered, and although that will still work, you will have to be careful not to over-drive the amp, [into constant clipping] as that will damage the VCs. 94</TD></TR></TABLE> wow thanx, i'll look into that.
m.glisson003
Audio / Security / Video
18
Aug 15, 2011 06:17 PM
vtec8804
Apr 19, 2007 11:58 AM
skrewdriver88
Dec 28, 2005 09:07 PM
sLo B18b
Dec 19, 2001 08:22 AM
woodog
Dec 17, 2001 11:08 PM
