FS: B16 longblock including cams, intake manifold, wiring harness...i need this thing gone!
motor was stolen...sorry cheech. these f**king thieves will go to hell. how they managed to steal an entire motor is beyond me, but they did it.
Modified by anothersickhatch at 5:41 PM 10/21/2006
Modified by anothersickhatch at 11:39 AM 10/24/2006
Does the Throttle Body Have the TPS? And will you let that go by itself?
PM'D
Modified by Yak BallZ at 4:47 PM 9/28/2006
PM'D
yes, its put together for the most part. im still waiting on some camshaft bolts and seals so that i can install the cams. it has around 50k, yes...just let me know man. i need this thing sold ASAP.
aiight ill let u know....have u ever dynoed the motor? any #'s? any problems anything i should know about??
with stage 1 cams the motor dyno'ed at 186 whp..it was hondata tuned by church. compression tested before i pulled the motor out and it was 260-265-260-265.
other than that, the oil pan gasket should be replaced. it might need a new timing belt and water pump. i will include a new oil pan gasket for you. thats pretty much it.
