milling b16 .020 and Buddy Club hg on stock ls/v
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
ok i have obd-0 b16 head that i milled .020 off and im running a buddy club HG. what i want to know is can i just pin the cams to tdc and spin the bottom end to tdc using the cam gears. i think that will work but here is my problem. with the obd-0 head im running 96 itr cams. well i cant pin the cams cause the holes are off and i have a set of obd-1 cam/oil rails (not the cam caps)just the rails ==== can i just use them on a obd-0 head. i need someone that knows for sure not a guessing game. also can somone tell me how much my cams will be on the + side? thanks for any help
92integraVTECgsr
Sep 26, 2010 05:02 AM
claytonsmith
14
Mar 7, 2007 06:37 AM
