burning oil or burning rich?
Old Sep 24, 2006 | 08:38 PM
sexyrex's Avatar
Default burning oil or burning rich?
recently had a used motor put in my 89 CRX Si, since i hydrolocked the last one...
since i've driven it with the new motor, i've noticed that it sometimes blows gray/black smoke above 4-5000rpm when i gas it. and will sometimes smoke around 2-3000rpm when cruising. its not a thick cloud of smoke, just smokes for a second or two. so i checked the cap, rotor, and plugs. and this was what i found:
cracks and arcing all around the inside of the cap, worn, black and crusty spark plugs, everything looks original, same goes for the o2 sensor.
would the faulty ignition cause the smoke?
Old Sep 24, 2006 | 10:31 PM
frankist's Avatar
cracked cap can cause hydrocarbon's. blackish smoke coming out the exhaust is fuel, grayish smoke coming out of there is water, blue would be oil. try replacing the cap, plugs, and wires like you were going to do and post back.
Old Sep 24, 2006 | 11:48 PM
sexyrex's Avatar
Default Re: (frankist)
for sure!
Old Sep 25, 2006 | 07:06 PM
sexyrex's Avatar
ok, so i replaced:
o2 sensor
pcv
cap
rotor
plugs
wires
fuel filter
runs alot smoother now with better pick-up. but, still smoking black at high rpm, above 4500rpm. it's not a huge cloud of smoke, just a little bit. actually better than before the tune-up. but i can notice it from the sideview mirror and standing at the rear of the vehicle. smells like fuel also.
so is it normal to burn rich while gassing it? or do i have other problems? any suggestions would help! thx in advance
ribal_gh
32
Apr 3, 2012 07:59 AM
j_wynn08
Jun 12, 2010 10:51 PM
Teamdiesel
12
Apr 25, 2006 06:21 AM
RallySportCivic
Mar 31, 2003 07:36 PM
nicksweetlude
Feb 2, 2002 08:32 AM
