93 prelude FLOOD problem
Old Sep 24, 2006 | 05:09 PM
hennessy's Avatar
Default 93 prelude FLOOD problem
Ok my 93 prelude has a leak somewhere. Everytime it rains the bottom of the back seats are always wet. I narrowed it down to what i believe is the problem and its the weather strips that are next to the sunroof and the strip that goes around the rear window. Do you guys think that this is the problem also? Should i buy the strips and install them myself? or should i have the professionals do it.
on top of the driver side door
strip around the rear window
Modified by hennessy at 6:19 PM 9/24/2006
Old Sep 24, 2006 | 05:18 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: 93 prelude FLOOD problem (hennessy)
watch it when its raining to see where the water is coming in at...
Old Sep 24, 2006 | 05:30 PM
esedulerp5tenin's Avatar
Default Re: 93 prelude FLOOD problem (AnthonyG2003)
haha, i've had this exact same problem twice. and it was the same culprit both times.
have you played with the rubber grommet/diaphragm on the top of the passenger footwell recently?? i forgot to properly seal this twice, and a **** load of water got in.
here:
Old Sep 24, 2006 | 07:17 PM
hennessy's Avatar
Default Re: 93 prelude FLOOD problem (esedulerp5tenin)
no i dont think that is the problem, because the only wet spots in the car are the bottoms of the back seats....i put my hand in the side of it and it has a lot of water under them. Does anyone have a diagram where all the screws are to remove the back seats?
Old Sep 24, 2006 | 07:28 PM
92LudeSI's Avatar
Check to make sure both sunroof drains are in place. Also take a hose and a friend and get in the car and have them spray the car to find out where its coming in.
Edit: to remove back seats there are little clips for the bottems you pull towards the front of the car and then the seats lift up. Then there are 2 bolts that you just take out and the seats pop up. and for the one that flips down I believe you have to pop open a little cover right by the hing onthe back of the seat and there are bolts there 2. Its been awhile though.
Modified by 92LudeSI at 10:46 PM 9/24/2006
Old Sep 24, 2006 | 10:56 PM
TylerC161's Avatar
a few months ago my whole passenger floorboard was flooded.. that shorted the ecu, locked the starter, and did one hell of a job on the flywheel.... in fact, im STILL working on getting the car back togeather..
although, that aside, i thought the leak was from the doors, since when i shut them hard and it rained again nothing happened.. well, it rained the other night, and my floorboard was full of water, AGAIN...
as posted above, its coming from the passenger plug thing, which i didnt even have in there.
Old Sep 26, 2006 | 04:24 PM
soto2635's Avatar
check ur trunk i had the same problem and it was comin in from the trunk wat i did was i put foam tape and around the light b/c thats were it was coming in from and it fixed it right up
Old Sep 26, 2006 | 07:51 PM
hennessy's Avatar
Default Re: 93 prelude FLOOD problem (soto2635)
can someone post pictures of their car, specifically the moldings going from the front windshield to the rear.
thanks for all the help
Old Sep 29, 2006 | 10:23 AM
92LudeSI's Avatar
The moldings on your roof that run from front to back are just for show, under them is just the roof of your car. It has to be coming in from either your trunk, seal around the back window, or doors.
Old Oct 21, 2006 | 06:15 AM
grantinator's Avatar
I'm having the exact same problem with my 92 accord... and i know the water isnt cmin in the trunk because its solid
Old Oct 21, 2006 | 08:58 AM
chau003's Avatar
Check the rear reflector markers on the rear bumper. Mine leaks on the driver side. We had a huge rainstorm here in MD back in July and my rear seats were soaked from all the water that collected in the spare wheel well and slushed around when I drove. It took me a while to figure out where the water seeped in from.
JaysenF135
Feb 1, 2006 09:06 AM
zeke mccune
May 26, 2004 07:09 AM
