tranny grinds.
Old Sep 24, 2006 | 05:07 PM
racingcrx's Avatar
Default tranny grinds.
i have a s1 B16 tranny i think the syncromesh is messed up on 3rd gear. and is it possible to have 2nd gear grind in high rpms? what would cause 2nd to grind? qould i need to get a tranny rebuilt.
Old Sep 24, 2006 | 05:13 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: tranny grinds. (racingcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racingcrx &raquo;</TD></TR><TR><TD CLASS="quote">i have a s1 B16 tranny i think the syncromesh is messed up on 3rd gear. and is it possible to have 2nd gear grind in high rpms? what would cause 2nd to grind? qould i need to get a tranny rebuilt. </TD></TR></TABLE>
it's dying out it seems EVERY b16a cable tranny is or has died out starting in 3rd gear.
Yes it is possible to have grind high rpm only, aviod it and don't go high rpm then.
You can do alot of differnt things to end these woes, easiest and cheapest is try some GM snyrcomesh in the tranny.
If you need more then rebuild swap converting to hyrdo all might be worth looking into.
Old Sep 24, 2006 | 06:26 PM
SF_EF8's Avatar
yup mine began to grind in higher rpms, eventually happens to all of them.... :-/
Old Sep 24, 2006 | 06:33 PM
Garage 808 Hatch's Avatar
Default Re: (SF_EF8)
dont feel bad, my old race tranny grinds 1st-5th
Old Sep 25, 2006 | 06:03 AM
gibsanez's Avatar
I'm pretty sure b16 tranny's come from the factory with 3rd gear grinds.
Syncromesh is the stuff people put in the transmission to help grinding synchronizers, so the syncromesh can't be "messed" up
MrExclusive
Feb 4, 2010 07:52 AM
wallawee
Jul 29, 2006 05:43 PM
civic16
May 1, 2006 02:29 PM
Vadian
Feb 4, 2003 12:32 AM
