HELP>>>HELP>>>>, engine slugish when vtec engages,
Old Sep 24, 2006 | 03:57 PM
HAMSTERHONDA's Avatar
Default HELP>>>HELP>>>>, engine slugish when vtec engages,
yes when my motor hits vtec it feels really slow and the rpms dont climb as fast, the only code i am throwing is one, which is o2 but i have ran my car many times without one, i have no knock sensor connected it is not throwing that code it is gsr in eg , it is obd1 with obd2 injector clips and injectors on it??? dont know if thats the reason but a buddy has done the same and his car runs fine, i have tried 2 different ecus still same result, making me crazy, the motor makes good power in the low but as soon as vtec, gets slow, , i can hear it engage , i dont know if it some kind of limp mode or what, the ecus work good in another car, i have no clue, some one told me it could be a clogged cat, so ran open header and still no dice, thanks for any input or help,on this problem
Old Sep 24, 2006 | 05:22 PM
Default Re: HELP>>>HELP>>>>, engine slugish when vtec engages, (HAMSTERHONDA)
help?? anyone,
Old Sep 24, 2006 | 05:23 PM
PinkMaggit's Avatar
try hooking up an 02 sensor yet?
Old Sep 24, 2006 | 06:52 PM
Default Re: HELP>>>HELP>>>>, engine slugish when vtec engages, (PinkMaggit)
im in the process of that right now, thanks , any other ideas?// thanks guys
Old Sep 24, 2006 | 08:15 PM
Mad Money's Avatar
Im having the same problem....did u switch over to bigger cams or something because your VTEC might be set to low
Old Sep 28, 2006 | 10:22 PM
Default Re: HELP>>>HELP>>>>, engine slugish when vtec engages, (Mad Money)
i wired up the o2 now no check engine light, its not throwing any codes, it started to do this after i put in a differnt gauge cluster and ecu, , ive tried different ecus still the same, i dont think it could really be the cluster, how ever i am going to change it back and try a non chipped ecu, and try differnt dizzy, thats all i could think of im pretty stumped,???
Old Sep 28, 2006 | 10:24 PM
as for the cams i had a stock gsr in the car and it was doing this so took it out said i would fix this problem later, it is now a fully built motor, still problematic
Old Oct 1, 2006 | 10:18 AM
changed gauge cluster,still acing up
Old Oct 1, 2006 | 03:57 PM
WELL THE MOTOR KIND OF WOKE UP TODAY, THE VTEC WAS WAY TOO LOW FOR THE CAMS IN IT, GOT A DIFFERENT ECU AND PLAYED WITH THE TIMING AND IT PULLS PRETTY HARD NOW, JUST NEED TO GET TUNED, THANKS
Old Oct 1, 2006 | 06:23 PM
B18B1_4DR's Avatar
JoshJosephKeith
11
Apr 30, 2009 06:29 AM
1clean_ Ej
Feb 28, 2007 08:07 PM
Xenobi
Jun 25, 2006 02:52 PM
UNDER PRESSURE
Jan 8, 2005 05:05 PM
jonas
Mar 15, 2003 03:09 PM
