Competition twin ??
Old Sep 24, 2006 | 03:18 PM
gdh8su's Avatar
Default Competition twin ??
I'm using a Competition twin disk clutch with a pedal stop. The question is I am having trouble with it not wanting to go into first gear without hitting second first. The more I adjust the stop out it seems to get get somewhat better. But I don't want to go too far and break the clutch. I had the new tranny apart to install the LSD and checked the whole setup out. Because I bought the tranny for $20 it was said to leak oil and not move when in gear. Now my last trans did this with the Competition and ate first gear syncro. Anybody know what might be causing this?
Modified by gdh8su at 8:27 PM 9/24/2006
Old Sep 24, 2006 | 03:48 PM
T Dohc's Avatar
Default Re: Competition twin ?? (gdh8su)
What car and tranny is it in. Have you also adjusted the rod on the master cyl? I have the cc twin in my car and have no problems out of it.
Old Sep 24, 2006 | 04:27 PM
gdh8su's Avatar
Default Re: Competition twin ?? (T Dohc)
99EK with a GSR also did it with the LS. No I have not adjusted the freeplay. Left alone from the Exedy twin. Do you think it needs less freeplay? Thanks
Old Sep 24, 2006 | 05:15 PM
DRAGLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gdh8su &raquo;</TD></TR><TR><TD CLASS="quote">99EK with a GSR also did it with the LS. No I have not adjusted the freeplay. Left alone from the Exedy twin. Do you think it needs less freeplay? Thanks</TD></TR></TABLE>
He is not asking about the free play adjustment he is asking if you adjusted the stroke of the master cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T Dohc &raquo;</TD></TR><TR><TD CLASS="quote"> Have you also adjusted the rod on the master cyl?</TD></TR></TABLE>
Old Sep 24, 2006 | 05:20 PM
Boostfed's Avatar
New User
Cortney , once you have the pedal stop adjusted it should shift fine in 1st, 2nd or whatever gear. Gimme a call tomorrow and I will try to help you out on it , if I can't we will conference Competition Clutch in and get you taken care of man.
Old Sep 24, 2006 | 05:46 PM
gdh8su's Avatar
Default Re: (Boostfed.com)
Thanks Terry will do. Adjusting the stroke didn't change anything. Just had to reset pedal stop and lost freeplay.
usdm_ED7
Transmission & Drivetrain
Aug 10, 2011 07:26 AM
DOMKID
18
May 16, 2006 06:24 PM
B18CJDM ITR
11
Apr 16, 2005 08:22 PM
0ptimus prime
Dec 21, 2003 01:07 PM
