Resistor box needed for a d16z6 in a 91 ef hatch
Old Sep 24, 2006 | 01:32 PM
94eg5squadMD's Avatar
Default Resistor box needed for a d16z6 in a 91 ef hatch
i jus got a question about a resistor box neeeded for my swap.... i got someone to do the swap n theres no resistor box...its a d16z6 in my 91 ef hatch....i got different opinions from people but i just wanted to kno what you guys think..thanks
Old Sep 24, 2006 | 03:01 PM
Rywire's Avatar
Default Re: Resistor box needed for a d16z6 in a 91 ef hatch (91hatchefkrew)
if you use the z6 inj, they dont run on a resistor box, the striped wires are 12V+
Old Sep 24, 2006 | 03:27 PM
89 civic si's Avatar
you got two options i am doing the same swap just swap over the injectors to make it easier but i must warn you if you are trying to stay obdo do not try i am waiting to get my ecu and conversion harness from rywire
Old Sep 24, 2006 | 05:41 PM
JOE BD-0's Avatar
I think Tyson has had one for sale forever now.....
Old Sep 25, 2006 | 09:34 AM
thanks for the replys but this is the thing... like i said someone i know is doing my swap for me... and i noticed that there is no resistor box..... im not sure what the resitor box does my buddy with a b16 ef hatch jus had to get a resitor box wired in...i asked the guy doing the swap for me bout the resitor box and he said newer motors have low "impede" or "impeads" or somethin like that n its not needed..... he told me when you have high "impeads" which is in older motors a resistor box is needed..... i dont kno if the impead thing im talkin bout is correct but what is the deal with injectors and the resistor box???..... i dont kno if this guy is too lazy to do the work or if hes is right about what he says thats why im asking for opions!!!... from what i kno on a d16z6 out of a eg hatch needs one.... its a obdo 1 motor obviously n a obdo car but all the wiring was done correctly....n im using the whole z6 setup n injectors. i just have a s2 manifold, imtake, cam gear, and headers. so keep the opinions going thanks
Old Sep 25, 2006 | 09:35 AM
bump
Old Sep 25, 2006 | 09:41 AM
Loserkidwac's Avatar
OBD0 cars have resistor box yes because the injecotrs are high impedience and new OBD1 cars like the EG don'e use them because they are low impedence...you can either use OBD0 inectors and keep the resistor box or convert to a non-resistor box set-up and keep the stock z6 injectors
Old Sep 25, 2006 | 09:46 AM
the resistor box ensures that only so much power goes to the injectors the z6 motor comes with 12v constant injectors..so in your situation you would just have to do a dpfi to mpfi swap and then the obd swap to use the p28 if you have any more questions ill help you out..i just did my own swap and got varied information i however already had the resistor box so i just used the obdo injectors and left the injector resistor box where it was and you will also have to swap over the drivers side mount and depin your distributor to match the distributor on the z6 oh and one more thing you must use your exhaust manifold from whatever you had in the car the downpipe wont match make sure you get the 4 wire o2 sensor also it is an easy swap if you take your time and do it right. i only have about 1000 dollars in my swap which some will say is too much but im happy
Old Sep 25, 2006 | 09:48 AM
ok thanks...so pretty much my setup is fine.... beause what your saying is if you use the z6 injectors theres no need for a resistor box needed... so what the guy told me about the low and high impediance was right.... thanks for your help man
Old Sep 25, 2006 | 10:02 AM
Default Re: Resistor box needed for a d16z6 in a 91 ef hatch (89 civic si)
im using the 12v constant injectors, when i bought the car with a d16z6 in it n i just got a newer rebiult one..so the dual point to multi point wiring was already done...and right now im using a b16 ecu but i'm going to use a pr4 ecu chiped and socketed tuned on chrome but, i also have a p28 but from what i heard you need a jumper harness or soemthing...and what are you talkin about with the O2 sensor im using a ebay header and downpipe with 2.5 catback image exhaust...thanks for the help guys
Old Sep 25, 2006 | 10:48 AM
bump
mikeyindigo
Apr 27, 2016 12:01 PM
EFvtec Yo!
Oct 22, 2008 05:32 AM
tinman25
Jul 29, 2008 06:47 PM
91SiRHatch
Jan 15, 2005 09:09 PM
kranked91dx
Oct 26, 2003 05:02 PM
