0bd0-obd1.with jumper harness...any write ups with pics out ther???
i have everything i need 4 the swap..at this moment its a d15b on obd0 wire harness..i just wanted 2 noe if anyone did a write up?
just buy the jumper harness and run your wires for vtec and o2 sensor and you will have to depin your distributor and match the colors for the 0bd1 distributor
i tryd that **** well i did it a lil better( i think) what i did was i took the plugs out of a obd0 dizzy and put them on a obd1 dizzy but still nothing.. is ther a link 2 depining them that shows what goes wher and what the deal with the injecter 2.?....thanx
rywire has the instructions for depping the distributor all the wire colors are the same but 2 and it tells you where to put what wire my question is are you already mpfi or did you conver from dpfi?
